How do you mask
Goto page 1, 2  Next
SVcummins
PostPosted: Thu May 09, 2019 6:31 pm    Post subject: How do you mask Reply to specific post Reply with quote
Off tires so you can paint the rims
showcrop
PostPosted: Fri May 10, 2019 3:48 am    Post subject: Re: How do you mask Reply to specific post Reply with quote
I don't usually. I take a piece of light cardboard and cut one long side to match the arc of the tire-rim. Then I hold it in place with one hand as I spray my way around with the other. Then cut a little hole in it and hang it on the wall for ten years later, LOL.
glennster
PostPosted: Fri May 10, 2019 3:49 am    Post subject: Re: How do you mask Reply to specific post Reply with quote
you prolly wont like it, but i dismount the tire, sandblast the rim, por15 goes on the inside, two coats, then expoxy prime and paint the exterior. for a down and dirty, let the air out and pop the bead, use cardboard cut out to cover the tire and squirt it.
SVcummins
PostPosted: Fri May 10, 2019 3:52 am    Post subject: Re: How do you mask Reply to specific post Reply with quote
I like that idea 💡
SVcummins
PostPosted: Fri May 10, 2019 3:55 am    Post subject: Re: How do you mask Reply to specific post Reply with quote
You?re right I don?t like it lol . Thats definitely the best way and If these weren?t rims I cobbled together out of pieces and parts from the junk yard I?d probably take the time to do that but this tractor is just an old work horse a long long way from being pretty just trying to shoot a little paint to make everything one color
ztrmowers
PostPosted: Fri May 10, 2019 5:22 am    Post subject: Re: How do you mask Reply to specific post Reply with quote
when I used to ones like that that did not have to be showroom I just rub some grease along rim on tire and spray grease rub off or wore off
rustyfarmall
PostPosted: Fri May 10, 2019 5:34 am    Post subject: Re: How do you mask Reply to specific post Reply with quote
CVPost-SVcummins wrote:
(quoted from post at 04:55:42 05/10/19) You?re right I don?t like it lol . Thats definitely the best way and If these weren?t rims I cobbled together out of pieces and parts from the junk yard I?d probably take the time to do that but this tractor is just an old work horse a long long way from being pretty just trying to shoot a little paint to make everything one color
A good, soft bristled brush will get the job done, and if the proper technique is used, the brush marks will be almost invisible. Smear some grease on the tires. If you get any paint on the grease, you can just wipe it off.
centash
PostPosted: Fri May 10, 2019 5:43 am    Post subject: Re: How do you mask Reply to specific post Reply with quote
Clean the rubber with some varsol, let it dry and then mask it off with tape. A bit more work than grease, but cleaner.
Ben
Stephen Newell
PostPosted: Fri May 10, 2019 7:10 am    Post subject: Re: How do you mask Reply to specific post Reply with quote
I go over the tires with shrink wrap up to about an inch of the rim and tape the rest. If labor was involved I would probably try liquid masking. It would be sprayed on the tires and after you are done would peal off. I don't know how much labor you would save. You would have to mask off the rim to spray the tire.
yakob
PostPosted: Fri May 10, 2019 9:21 am    Post subject: Re: How do you mask Reply to specific post Reply with quote
showcrop wrote:
(quoted from post at 06:48:08 05/10/19)
Same here but only when not unmoubting which was already mentioned. It's nice to get inside especially because it seems like people really enjoyed calcium back in the day!
showcrop
PostPosted: Fri May 10, 2019 5:54 pm    Post subject: Re: How do you mask Reply to specific post Reply with quote
yakob wrote:
(quoted from post at 10:21:13 05/10/19)
People still "enjoy" calcium not so much in the older tractors but in the newer ones that are still working. They pump it into the tubeless tires.
yakob
PostPosted: Sat May 11, 2019 4:12 am    Post subject: Re: How do you mask Reply to specific post Reply with quote
I don't think I've seen but a handful of our restoration jobs without calcium in this neck of the woods. It's almost a given to find a set of rims on a lot of these.
Stephen Newell
PostPosted: Sat May 11, 2019 5:58 am    Post subject: Re: How do you mask Reply to specific post Reply with quote
If I were going to break a tire down to paint I would paint only the inside until the tire was back on. I've never seen a tire person put a tire on anything without tearing the paint all to H. One place I took a car tire to put a UPC sticker on the rim and I destroyed the paint trying to get it off. The paint was dry but not fully cured yet.
SVcummins
PostPosted: Sat May 11, 2019 6:57 am    Post subject: Re: How do you mask Reply to specific post Reply with quote
Thanks for all the replies guys Gave me several good ideas
44 massey
PostPosted: Sat May 11, 2019 7:02 am    Post subject: Re: How do you mask Reply to specific post Reply with quote
I use 2 inch masking tape ( make sure tire is clean so tape will stick) about 1 ft strips go completely around the rim, then take a razor go around between tire and rim, peel off inside, the use masking 6 in wide or wider paper and tape it to the masking tape on the tire! Works for me!!
Post new topic    Yesterday's Tractors Forum Index -> Paint and Bodywork All times are GMT - 8 Hours
Goto page 1, 2  Next
Page 1 of 2
