Can't remove starter on late 40s model 8N Tractor
elife1975
PostPosted: Fri Jun 07, 2019 6:55 am    Post subject: Can't remove starter on late 40s model 8N Tractor Reply to specific post Reply with quote
Hello,
It was recommended I post here instead of the Ford 8N forum in case there's a difference with my model tractor. I was under the impression the Ford and Ferguson 8Ns were identical but maybe not. My starter has a short and is mounted on the left side of the motor but I can't remove it as it's butted up against the distributor that sits directly in front of it. I've attached a crude drawing of my dilemma in case any of you fine folks has any input. This was a tractor I'd inherited recently and motors are not my strong suit. Photo attached as well...only one I had readily available. Appreciate the help!
John Deere D
PostPosted: Fri Jun 07, 2019 7:18 am    Post subject: Re: Can't remove starter on late 40s model 8N Tractor Reply to specific post Reply with quote
you have a FERGUSON TRACTOR.......
Place your post on the FERGUSON section..
FORD....FERGUSON..
Different MOTHERS and Different FATHERS....
Henry F. and Harry F. shared the Three point hitch, Hydraulic Pump...front Axel.... for a short period of time...
I own a FORD 2-N as well as a Ferguson TEA-20.......
Then their is the GRAY FERGUSON built in England ..and the GRAY FERGUSON built in the USA....different Engines.
Bob...
markct
PostPosted: Sun Jun 09, 2019 3:42 am    Post subject: Re: Can't remove starter on late 40s model 8N Tractor Reply to specific post Reply with quote
I think the answer is pretty obvious, remove the distributor
tractorguy2
PostPosted: Sun Jun 09, 2019 6:31 pm    Post subject: Re: Can't remove starter on late 40s model 8N Tractor Reply to specific post Reply with quote
There is no such tractor as a Ferguson 8n. You have either a TO20 or TO30 Ferguson tractor. The starter will not come out without removing the distributor first.
cdmn
PostPosted: Sun Jun 09, 2019 7:48 pm    Post subject: Re: Can't remove starter on late 40s model 8N Tractor Reply to specific post Reply with quote
I think it's interesting to note that the Fordson Dexta with Standard Engine, moved the starter to the other side.
elife1975
PostPosted: Mon Jun 10, 2019 4:28 am    Post subject: Re: Can't remove starter on late 40s model 8N Tractor Reply to specific post Reply with quote
I was hoping it wasn't that obvious, obviously.
HFJ
PostPosted: Mon Jun 10, 2019 12:02 pm    Post subject: Re: Can't remove starter on late 40s model 8N Tractor Reply to specific post Reply with quote
"what we have here is failure to communicate." for future reference:
u own a ferguson tractor. that's not a ford, and it's not a fordson. u are more likely to get the help u need if u post your questions in the forum that corresponds to the brand of tractor u actually have.
click here for the correct forum to ask questions about ferguson tractors.
elife1975
PostPosted: Mon Jun 10, 2019 12:07 pm    Post subject: Re: Can't remove starter on late 40s model 8N Tractor Reply to specific post Reply with quote
Gotcha, thanks.
Kirk-NJ
PostPosted: Tue Jun 25, 2019 12:30 am    Post subject: Re: Can't remove starter on late 40s model 8N Tractor Reply to specific post Reply with quote
Not sure why you can't remove the starter. See video at about the 120 mark this guy pulls starter on a TO20 ferguson. Worse case mark the dizzy and pull it.
Untitled URL Link
Tramway Guy
PostPosted: Wed Jun 26, 2019 9:06 am    Post subject: Re: Can't remove starter on late 40s model 8N Tractor Reply to specific post Reply with quote
American built Ferguson TO20 and Britsh-made TE20 had the same Continental Z120 engine. Electrics were different along with some castings.
Post new topic    Yesterday's Tractors Forum Index -> Fordson All times are GMT - 8 Hours
