Brush hog shear bolt
JayinNY
PostPosted: Sun Jun 09, 2019 12:32 pm    Post subject: Brush hog shear bolt Reply to specific post Reply with quote
I have shear bolts on hand for my Howse brush hog, but there to big for my woods mower, I can't remember, are they grade 5 or 8?
johnofnewhaven
PostPosted: Sun Jun 09, 2019 1:10 pm    Post subject: Re: Brush hog shear bolt Reply to specific post Reply with quote
I use grade five in my old Bush Hog.
JayinNY
PostPosted: Sun Jun 09, 2019 1:29 pm    Post subject: Re: Brush hog shear bolt Reply to specific post Reply with quote
Thank you
Billy NY
PostPosted: Sun Jun 09, 2019 6:32 pm    Post subject: Re: Brush hog shear bolt Reply to specific post Reply with quote
I would be careful, anyway you could check the specification in the manual ? I use 1/2" Grade 2 in my old Rhino SE-6. They work perfectly, there is no way I would want a Grade 5 on this mower, way too much shock load transfer to the drive line. They tolerate a certain amount of abuse, then shear. You'll get a couple of bumps before it shears. The tractor is a late model ford/nh 4630, which has much more torque than the tractor it replaced, an 850. It will shear if you engage the pto too quickly, and the shear bolt has double nuts, which are tight. I ran this mower behind the 850 for 14 years, used the same grade 2 bolts, they lasted years, it just did not have enough torque unlike the 4630.
I get a dozen every year and use most when getting into thick brush or hit a log, rock or even a tussock near the swamp. Ran 9.6 hours getting my fields cut since friday and sheared 2 bolts towards the end of that time. Once was got too close to a stump I knew was there, shredded some old vines, the other was engaging the pto quickly, blade was hitting the side skirt, I reacted quickly, brain fart, was still spinning, well crap, it's not off, moved the lever back quickly as if shutting it off, had it backwards, immediately sheared the bolt.
I'm thinking it's time for a new mower with a slip clutch for this 4630, I certainly can change them quickly with all the practice. I have seen what happens with a JD 2020 and a 5' M-F rotary mower, they used a Grade 8 in it. The 2020 had to be split and disassembled to get to the pto coupler, it broke from the shock loads.
JayinNY
PostPosted: Sun Jun 09, 2019 6:46 pm    Post subject: Re: Brush hog shear bolt Reply to specific post Reply with quote
I only use my brush hogs to mow pasture grass,
the Howse takes the bottom bolt, I think when I bought it 14 years ago the bolt was in bad shape, so I bought a few to have on hand, my woods m5 Dixie cutter has been run with the bolt on top, which I had no idea was in there until yesterday, Iv been running it like that for many years, someone put the bolt in and just bent it over, so I want to get a bolt and nut for it.
Billy NY
PostPosted: Mon Jun 10, 2019 3:14 am    Post subject: Re: Brush hog shear bolt Reply to specific post Reply with quote
Grasses, no problem, just remember its a grade 5 if you ever have work in harsh conditions, as much as it's inconvenient to change out, your tractor won't take the abuse. I'm actually impressed at how much these grade 2 bolts take, the coupling to the input shaft on the gearbox is not exactly tight, but the shear bolts with double nuts seem to work well, they shear perfectly like they should. One year I hit a good size round rock with the 850 running it, it sheared the shoulder bolts on the stump pan blade holder and the driveline shear bolt, so I guess there is double protection, never sheared those shoulder bolts since.
James Howell
PostPosted: Mon Jun 10, 2019 7:14 am    Post subject: Re: Brush hog shear bolt Reply to specific post Reply with quote
"there is no way I would want a Grade 5 on this mower"
Agree.
We use Grade 2 and buy them by the pound at TSC.
Much cheaper than repairs on a John Deere Model 70.
Post new topic    Yesterday's Tractors Forum Index -> Implement Alley All times are GMT - 8 Hours
