Welding engine block
Bill from Scotland
PostPosted: Wed Jun 26, 2019 2:18 pm    Post subject: Welding engine block Reply to specific post Reply with quote
I've a frost damaged engine block, large chunk out the side of the engine. I'm guessing it will weld but develop small cracks as it cools. Could the repair be coated by JD weld and a can of internal sealant be poured into the cooling system. What are the chance this will work?
Steve@Advance
PostPosted: Wed Jun 26, 2019 2:41 pm    Post subject: Re: Welding engine block Reply to specific post Reply with quote
It might work, but then it might not...
There could be other damage elsewhere too.
If it's yours, and just want to give it a try, not much to loose at this point.
If it's a large flat area, I've seen a plate bolted in place with a thick gasket or epoxy behind it.
The sealer will stop small leaks. Follow the directions, most require a pressurized system to work, so be sure the thermostat and rad cap are good.
Stephen Newell
PostPosted: Wed Jun 26, 2019 2:58 pm    Post subject: Re: Welding engine block Reply to specific post Reply with quote
Probably anything you do for it won't hold. If you can't find a replacement block you might try lock and stitch and then braze the seam. If you have chunks out I don't see how you could not have water jacket issues you wouldn't be able to get to.
teddy52food
PostPosted: Wed Jun 26, 2019 4:49 pm    Post subject: Re: Welding engine block Reply to specific post Reply with quote
I had a 67 440 Chrysler that broke a rod & put a hole in each side under the water jacket. I broke up & ground pieces of cast to fit the holes. Welded a little at a time with 99 nickel rod. Put another 80 or 90 thousand on it before I sold it.
VicS
PostPosted: Wed Jun 26, 2019 5:16 pm    Post subject: Re: Welding engine block Reply to specific post Reply with quote
I've got a fortune in a block with a hole 3". I cleaned it with alcohol, dried it with air. Then laid screen wire over the hole pushed it down into the hole a little then put another piece over the top. JB Welded it 1/2" deep. Hope it holds a long time.
george md
PostPosted: Thu Jun 27, 2019 7:34 pm    Post subject: Re: Welding engine block Reply to specific post Reply with quote
Do yourself a big favor , don't weld it . Look on line for lock n stitch
pins , they work. If you need more info send me an email and I'll send you some
pictures. I did a 427 ford side oiler last year , took 125 pins but when done
it did not leak under pressure . It was cracked in both banks.
Beginning the lock n stitch repair
georger
David G
PostPosted: Fri Jun 28, 2019 5:09 pm    Post subject: Re: Welding engine block Reply to specific post Reply with quote
Unless it is irreplaceable, just easier to get a different block.
M-MAN
PostPosted: Sat Jun 29, 2019 2:40 am    Post subject: Re: Welding engine block Reply to specific post Reply with quote
I have seen several Deere's with big chunks like that welded back in. Some were done with plain old 7018 and held up fine. Depends on cleanliness and your welding skill. No it isn't the prettiest but it works.
jtwat
PostPosted: Mon Jul 01, 2019 7:56 pm    Post subject: Re: Welding engine block Reply to specific post Reply with quote
Go to www.muggyweld.com
They have welding rods that work on cast.
jtwat
PostPosted: Mon Jul 01, 2019 7:59 pm    Post subject: Re: Welding engine block Reply to specific post Reply with quote
https://www.muggyweld.com/
