Custom Wiring Harness
euswdwj@yahoo.com
PostPosted: Tue Jul 02, 2019 4:41 am    Post subject: Custom Wiring Harness Reply to specific post Reply with quote
Hi All!
Am ready to rewire the Ferguson TO-35 to make it safe again.
A starter button and solenoid are now in place and would like to bring the neutral safety switch back into the circuit. Also the Generator has been replaced with a one-wire alternator.
As there are no wiring diagrams that include these alterations I made up my own.
My questions are two:
What wire gauges would be best to use?
Where do in-line fuses need to be placed and with what amperage?
Anything else you can think of?
Bob
PostPosted: Tue Jul 02, 2019 7:14 am    Post subject: Re: Custom Wiring Harness Reply to specific post Reply with quote
The way you have them Ammeter connected, it will only show alternator output. Batter power should connect to one side, alternator and all electrical loads to the other.
Why are you feeding power to the ignition switch with a 16 GA wire, then continuing to the coil and distributor with (heavier) 14 GA wire?
Steve@Advance
PostPosted: Tue Jul 02, 2019 7:29 am    Post subject: Re: Custom Wiring Harness Reply to specific post Reply with quote
Everything looks good except the accessories need to be wired to the same side of the amp meter as the alternator.
I would go up to 14ga where you have 16ga.
The 16ga will work, but 14 will be just a little more forgiving of vibration.
When buying the wire, go with the low voltage automotive wire, not THHN building wire. The automotive wire is more flexible, easier to work with, finer strand for vibration resistance.
The ground strap from the battery, originally it was attached to the sheet metal behind the battery. That was a common source of problems, I would connect it to something on the engine itself, like a bell housing bolt.
It would only need one fuse, a 15a in the line from the amp meter to the key switch.
Get some of the split black wire loom and some metal straps to secure the loom. It makes for a really pro looking job.
Wire Loom
JMOR
PostPosted: Tue Jul 02, 2019 7:38 pm    Post subject: Re: Custom Wiring Harness Reply to specific post Reply with quote
euswdwj@yahoo.com wrote:
(quoted from post at 08:41:36 07/02/19) Hi All!
Ammeter should between battery and all else, excepting starter, of course.
euswdwj@yahoo.com
PostPosted: Fri Jul 05, 2019 8:42 pm    Post subject: Re: Custom Wiring Harness Reply to specific post Reply with quote
Thanks for pointing out that the accessories go on the alternator side of the Ammeter. Is this to help indicate parasitic draw on the battery?
Also thanks for providing the location and the amperage of the fuse.
Here is a revised wiring diagram. Please comment on wire gauge and anything else you would like to suggest:
