Oliver super 77 aftermarket hydraulics
Goto page Previous  1, 2
popcornob
PostPosted: Mon Jul 15, 2019 12:33 pm    Post subject: Re: Oliver super 77 aftermarket hydraulics Reply to specific post Reply with quote
chucksoliver77 wrote:
(quoted from post at 12:10:47 07/15/19) You will need the pto support/bushing if you plan on using the pto after you remove the pump.
where does the support bushing go on a delete plate?
chucksoliver77
PostPosted: Mon Jul 15, 2019 1:35 pm    Post subject: Re: Oliver super 77 aftermarket hydraulics Reply to specific post Reply with quote
No it bolts to the transmission and the pto shaft slides through it
rrlund
PostPosted: Tue Jul 16, 2019 4:38 am    Post subject: Re: Oliver super 77 aftermarket hydraulics Reply to specific post Reply with quote
I'm not laughing at anybody,but this kind of thing always reminds me of something Dad did when I was a kid.
He had a New Holland PTO driven side rake that had three wheels. There was two in the back and a caster wheel in front. He blew out the tire on that castor and didn't want to spend the money on a new one. He spent most of the day going through the iron pile and welding up a different hitch to eliminate the caster. When he took the jack out from under it,everything sagged so bad that it was obvious it wasn't going to work.
The air turned blue from the cussing,then he jumped in the truck and shot off to town to get a new tire and fix it right. He wasted an entire day,a bunch of steel and welding rod and still had to spend the money to fix it right. I've got a strong suspicion you'll be in the same boat at the end of the day,getting the original pump fixed and trying to sell all of the new parts you bought on Craigs List for half price.
popcornob
PostPosted: Tue Jul 16, 2019 10:03 am    Post subject: Re: Oliver super 77 aftermarket hydraulics Reply to specific post Reply with quote
CVPost-rrlund wrote:
(quoted from post at 05:38:40 07/16/19) I'm not laughing at anybody,but this kind of thing always reminds me of something Dad did when I was a kid.
I know exactly what you are talking about. This situation is that if the pump got replaced the relief valve is also pitted really bad. My thought was instead of throwing a 400$ plate or pump on it I could spend maybe 800 and get more responsive hydraulics, add a 3rd control valve for 3 point or log splitter etc, and enough gpm to add other implements if needed.
Traditional Farmer
PostPosted: Tue Jul 16, 2019 10:07 am    Post subject: Re: Oliver super 77 aftermarket hydraulics Reply to specific post Reply with quote
Same way with motors in garden tractor 30 years and blew up so the owner thinks a different brand motor will be better spends a bunch of $$$ and the different motor never really works like it should as the tractor was designed for the original motor.Lost count of the number of tractors I've bought that were repower projects that were given up on after a pile of $$$$ was spent. .
Olliejunkie
PostPosted: Tue Jul 16, 2019 2:43 pm    Post subject: Re: Oliver super 77 aftermarket hydraulics Reply to specific post Reply with quote
popcornob wrote:
(quoted from post at 11:03:02 07/16/19)
You can put as many valves as you like on the original but your power will still be limited. I have a s88 with a loader. It easily lifts 1200 lbs. so I am plenty happy with the pressure.
Centerplate
PostPosted: Thu Jul 18, 2019 2:51 am    Post subject: Re: Oliver super 77 aftermarket hydraulics Reply to specific post Reply with quote
Centerplate for that pumps is $235 plus shipping
nfaessler@wildblue.net
Alvin 41
PostPosted: Thu Jul 18, 2019 5:45 pm    Post subject: Re: Oliver super 77 aftermarket hydraulics Reply to specific post Reply with quote
I've got 2 extra plate-resevoir-2 lever valves for 770's, but only one pump which needs rebuilding. There is a local pump rebuilder at Juda WI who can supply new parts.The reservoir is limiting in capacity.
popcornob
PostPosted: Mon Jul 22, 2019 7:00 am    Post subject: Re: Oliver super 77 aftermarket hydraulics Reply to specific post Reply with quote
Olliejunkie wrote:
(quoted from post at 10:36:07 07/15/19) I have a 77 and 88 with front mount pumps. The 88 works well.
Where is the hydraulic reservoir on it?
Olliejunkie
PostPosted: Mon Jul 22, 2019 7:28 am    Post subject: Re: Oliver super 77 aftermarket hydraulics Reply to specific post Reply with quote
popcornob wrote:
(quoted from post at 08:00:19 07/22/19)
The 77 is incorporated into the loader. 88 is under hood over engine. Kinda small and has a hole in hood to fill.
popcornob
PostPosted: Mon Jul 22, 2019 10:50 am    Post subject: Re: Oliver super 77 aftermarket hydraulics Reply to specific post Reply with quote
Alvin 41 wrote:
(quoted from post at 18:45:36 07/18/19) I've got 2 extra plate-resevoir-2 lever valves for 770's, but only one pump which needs rebuilding. There is a local pump rebuilder at Juda WI who can supply new parts.The reservoir is limiting in capacity.
Interested. Let me clarify, these are all stock parts? 2 center plates for the pump, the cast reservoir housing, 2 valve levers, and one whole pump that needs rebuild ie seals and bearings?
Page 2 of 2
