Broken pitman stick
Goto page Previous  1, 2, 3  Next
Roger in Iowa
PostPosted: Thu Jul 18, 2019 6:04 pm    Post subject: Re: Broken pitman stick Reply to specific post Reply with quote
Might try raising the tip of the guards up to help the cut material flow off the cutterbar. Won't cut as close to the
ground but would help reduce the load on the cutting components, by not recutting the cut material.
MtMan
PostPosted: Thu Jul 18, 2019 6:28 pm    Post subject: Re: Broken pitman stick Reply to specific post Reply with quote
You should have a slip clutch on the PTO shaft. Look and see if it is working properly. It should slip before any thing gets broken. The clutch should maybe be adjusted. Make sure it's not rusted together.
Traditional Farmer
PostPosted: Thu Jul 18, 2019 6:32 pm    Post subject: Re: Broken pitman stick Reply to specific post Reply with quote
Pitman mowers have their limit as to what they will cut,and if a section has had a grinder to it,it ain't ever really sharp again.Look for a JD 350/450 or a NH 451/456.
300guy
PostPosted: Thu Jul 18, 2019 7:02 pm    Post subject: Re: Broken pitman stick Reply to specific post Reply with quote
I broke several sticks on my old IH 27V mower because the slip clutch was set too tight. I finally set it really loose so any clog would ratchet the clutch and no more broken sticks.
jacksun65
PostPosted: Thu Jul 18, 2019 7:47 pm    Post subject: Re: Broken pitman stick Reply to specific post Reply with quote
Listen to the mower sounds like you are going to fast for the crop. It will talk when the chatters sound more like a thump slow down.
Lazy WP
PostPosted: Thu Jul 18, 2019 10:25 pm    Post subject: Re: Broken pitman stick Reply to specific post Reply with quote
Throw away the single guards. Set the register
correctly. (I disagree with SVCummins as they have
to shear the same both directions no matter what
brand) angle your bar up in front a bit, make sure
your hold downs are close but not in a bind. Slow
the rpms down to about 350 on the pto. LISTEN TO
THE MOWER if it?s talking you are abusing it.
I have broken my share of pitman sticks but usually
it?s from hitting a stump or T post.
I have NEVER SEEN a slip clutch on a mower and I
have operated many.
Leroy
PostPosted: Fri Jul 19, 2019 4:18 am    Post subject: Re: Broken pitman stick Reply to specific post Reply with quote
Only on certain models, The No. 5 is center to center.
SVcummins
PostPosted: Fri Jul 19, 2019 5:50 am    Post subject: Re: Broken pitman stick Reply to specific post Reply with quote
Again From the manual you do not time a John Deere that way! It travels passed the same distance both ways you can disagree all you want but it isn?t right
James Howell
PostPosted: Fri Jul 19, 2019 8:27 am    Post subject: Re: Broken pitman stick Reply to specific post Reply with quote
"have NEVER SEEN a slip clutch on a mower"
Take a look at the POWER SHAFT, TRACTOR TO MOWER diagram below.
Note the slip clutch descriptions (Key 8 - Key 14).
Take a look at the photo below.
Hope this helps.
SVcummins
PostPosted: Fri Jul 19, 2019 8:40 am    Post subject: Re: Broken pitman stick Reply to specific post Reply with quote
The only limit the Have is people that won?t read the manual and won?t adopt the ideas used on the newer mowers I can cut short wiry grass or triticale 8 mph with no issues
SVcummins
PostPosted: Fri Jul 19, 2019 9:34 am    Post subject: Re: Broken pitman stick Reply to specific post Reply with quote
The biggest problem people have getting a machine to work is failing to either read or failure to understand how and why you adjust it . Here?s the right way and even the sales brochure on why it?s that way
Traditional Farmer
PostPosted: Fri Jul 19, 2019 9:59 am    Post subject: Re: Broken pitman stick Reply to specific post Reply with quote
You are running 8 MPH with a pitman mower? Some of the guys with disc mowers need to trade for your sickle bar(LOL)
lastcowboy32
PostPosted: Fri Jul 19, 2019 10:50 am    Post subject: Re: Broken pitman stick Reply to specific post Reply with quote
My guess is that it's out west somewhere.
In those fields on the prairie, two men can lay down at opposite ends of the field a quarter mile apart, and still see each other through the grass stems.
I have patches of thin, wiry grass that are thick as hair on a dog, and I'll eat a hot steaming plop from said dog if anyone buzzes through it at 8MPH with a sickle mower.
That being said, reading the advice I've seen, I'm sure that SV's sickle mower is tuned in top notch condition.
Farmallb
PostPosted: Fri Jul 19, 2019 11:38 am    Post subject: Re: Broken pitman stick Reply to specific post Reply with quote
Who sharpened your sections? I always thought I could sharpen a sickle, but I finally took mine to
a professional sharpening business, and they did a great job some 20yrs ago. Need to do it again.
showcrop
PostPosted: Fri Jul 19, 2019 2:04 pm    Post subject: Re: Broken pitman stick Reply to specific post Reply with quote
Wildsawmill, I bet you won't look for advice here again, LOL.
Post new topic    Yesterday's Tractors Forum Index -> Implement Alley All times are GMT - 8 Hours
Page 2 of 3
