1965 voltage regulator identifacation
marlin54
PostPosted: Thu Jul 18, 2019 9:11 pm    Post subject: 1965 voltage regulator identifacation Reply to specific post Reply with quote
I have a 65 model and I think it has the original 12 volt generator and regulator...the generator has just 1 terminal marked F ....then it has this regulator with markings from right to left....B.....then F then WL then D then E.......are both of these original equiptment and where does the wires basically .... Does anyone know how wire it to make it charge ?
Majorman
PostPosted: Fri Jul 19, 2019 2:52 am    Post subject: Re: 1965 voltage regulator identifacation Reply to specific post Reply with quote
B = Battery live terminals.To "Batt" on Key starter switch, second to solenoid.
F = Dynamo Field.
WL = Dynamo Warning Light.
D = Dynamo Positive.
E = Earth/Ground.
Colours: Brown, Brown, Brown/Green, Brown/Yellow, Brown/Yellow, Black.
B B F WL D E
RickB
PostPosted: Fri Jul 19, 2019 2:53 am    Post subject: Re: 1965 voltage regulator identifacation Reply to specific post Reply with quote
Battery
Field ( on generator)
Warning Lamp
Earth (ground)
I?m drawing a blank on the D. Was expecting it to be G for Generator (armature)
JMOR
PostPosted: Fri Jul 19, 2019 6:23 am    Post subject: Re: 1965 voltage regulator identifacation Reply to specific post Reply with quote
CVPost-marlin54 wrote:
(quoted from post at 01:11:05 07/19/19) I have a 65 model and I think it has the original 12 volt generator and regulator...the generator has just 1 terminal marked F ....then it has this regulator with markings from right to left....B.....then F then WL then D then E.......are both of these original equiptment and where does the wires basically .... Does anyone know how wire it to make it charge ?
<img src="/cvphotos/cvphoto30129.jpg">
<img src="/cvphotos/cvphoto30130.jpg">
<img src="/cvphotos/cvphoto30131.jpg">
Look on back , around tach drive for another terminal.
sotxbill
PostPosted: Fri Jul 19, 2019 6:38 am    Post subject: Re: 1965 voltage regulator identifacation Reply to specific post Reply with quote
that gen must have a big terminal sticking out the back,, or its been broke off.
Destroked 450
PostPosted: Fri Jul 19, 2019 9:41 am    Post subject: Re: 1965 voltage regulator identifacation Reply to specific post Reply with quote
That a aftermarket generator, the sell it on this site.
Site photo shows another terminal below the tach drive near the engine block.
