351 carb
kenbob
PostPosted: Sun Jul 21, 2019 11:15 am    Post subject: 351 carb Reply to specific post Reply with quote
Took my 351 on a 53 mile tractor ride yesterday. THe carb we had so much trouble with being lean is fixed. Have good power and smooth the tractor really goes. It runs smoothly at idle and under load, but when coasting or idling down there is lots of snap crackle and pop out the exhaust. Tried several adjustments on the carb but it hasn't seemed to help. Any advice?
Joe (Wa)
PostPosted: Sun Jul 21, 2019 12:22 pm    Post subject: Re: 351 carb Reply to specific post Reply with quote
CVPost-kenbob wrote:
(quoted from post at 20:15:33 07/21/19) Took my 351 on a 53 mile tractor ride yesterday. THe carb we had so much trouble with being lean is fixed. Have good power and smooth the tractor really goes. It runs smoothly at idle and under load, but when coasting or idling down there is lots of snap crackle and pop out the exhaust. Tried several adjustments on the carb but it hasn't seemed to help. Any advice?
After fire in the exhaust is usually lean mixture.
kenbob
PostPosted: Sun Jul 21, 2019 1:59 pm    Post subject: Re: 351 carb Reply to specific post Reply with quote
Thanks, At least I know which direction to go with the carb.
kenbob
PostPosted: Sun Jul 21, 2019 3:14 pm    Post subject: Re: 351 carb Reply to specific post Reply with quote
joe, would you know which needle is too lean--Power or Idle?
kevinthefixer
PostPosted: Sun Jul 21, 2019 5:31 pm    Post subject: Re: 351 carb Reply to specific post Reply with quote
If it's happening with the throttle butterfly closed, it's idle mix. A leaky exhaust manifold or gasket or headpipe can also cause that.
kenbob
PostPosted: Sun Jul 21, 2019 6:47 pm    Post subject: Re: 351 carb Reply to specific post Reply with quote
Thanks, I need to recheck the manifold. I switched it from up flow to down flow and used new gaskets but i am a chicken when it comes to tightening old stuff...especially manifold nuts or bolts. Really don't want to twist one of those off. I may need to feel for leaks and retighten.
kevinthefixer
PostPosted: Mon Jul 22, 2019 4:03 am    Post subject: Re: 351 carb Reply to specific post Reply with quote
Hold a rag in the tailpipe while it's idling, or have someone else do that while you feel and listen.
kenbob
PostPosted: Mon Jul 22, 2019 6:00 am    Post subject: Re: 351 carb Reply to specific post Reply with quote
You probably nailed it. When I got the tractor last year I took it on a ride. It was lean then and had to run with the choke out. Since then we got the carb working by taking out the economizer valve and I did the change on the manifold from up to down. It ran great on short trips. I am guessing that is where the problem is. It probaby loosened up a little after some run time.
chuck machinist
PostPosted: Tue Jul 23, 2019 12:55 pm    Post subject: Re: 351 carb Reply to specific post Reply with quote
I feel your pain when it comes to torqueing intake and exhaust manifolds. Stay within the specs, and if it continues to leak , you resurface ,and or replace with a gasket. CM. Gremlins no longer live in my shop! But they live just outside the door.
Joe (Wa)
PostPosted: Tue Jul 23, 2019 2:05 pm    Post subject: Re: 351 carb Reply to specific post Reply with quote
CVPost-chuck machinist wrote:
(quoted from post at 21:55:43 07/23/19) I feel your pain when it comes to torqueing intake and exhaust manifolds. Stay within the specs, and if it continues to leak , you resurface ,and or replace with a gasket. CM. Gremlins no longer live in my shop! But they live just outside the door.
Manifolds usually have brass nuts so not common to strip the threads on the ferrous stud but they tend to thermal flex at a different rate than the stud and require retorque. Torque is 30 ft lbs on 300 G148 engine, about normal for a small Case engines.
Joe
