D8K front crank seal
NothinbutaCAT!!
PostPosted: Sat Apr 21, 2007 7:00 pm    Post subject: D8K front crank seal Reply to specific post Reply with quote
I was out this morning knocking down some bush for the nieghbors and my K started to spew oil out the front of the crank. I got it all torn apart, Any tips on changing the seal itself?
bob lyle
PostPosted: Mon May 21, 2007 5:38 am    Post subject: Re: D8K front crank seal Reply to specific post Reply with quote
Hi; You need to lift the rad.Pull the damper. Get a slid puller hammer. Put three spaced holes in. Space these holes. Use a hook seal remover or screw in slide hammer. If you go to a rental cat store their is a kit to re & re the front seal. These seals from cat has a sleeve that comes with them. This sleeve should be removed.
Hope this will help.
