No oil in filter when removed
Case450
PostPosted: Mon Apr 30, 2007 7:33 am    Post subject: No oil in filter when removed Reply to specific post Reply with quote
I am servicing my case 450 crawler loader (diesel engine) and I removed the skid plate and clean up the engine bay. I removed the oil drain plug (the washer aroudn teh head of the plug was all eaten up - can I replace this with a regular "O-ring"?) and drained teh oil out.
When I went to remove the filter no oil fell out of the filter or where the filter screws on. Is this normal and if not, how do I correct?
Roy Suomi
PostPosted: Mon Apr 30, 2007 3:51 pm    Post subject: Re: No oil in filter when removed Reply to specific post Reply with quote
How long has the machine sat without running?? Are you using the correct filter ?? Some filters have a check valve to keep oil from draining back to sump..Try using a Case New Holland filter once just for giggles...Take your drain plug to an auto parts store..Most have a selection of washers , copper , aluminum , fiber to fit most all drain plugs..
Case450
PostPosted: Mon Apr 30, 2007 6:40 pm    Post subject: Re: No oil in filter when removed Reply to specific post Reply with quote
It was a case oil filter that i removed. The machine has been sitting for about four or five days I guess. this makes me wonder though if the motor is temporarily starved of oil on start up? I fixed the o ring easy enough and i just got all new filters today...should be rolling my lunch tomorrow.
JFoshee
PostPosted: Mon Apr 30, 2007 8:35 pm    Post subject: Re: No oil in filter when removed Reply to specific post Reply with quote
Your crawler most likely has the 188 engine with the oil filter being on the right side of the engine laying horizontal. If your crawler has sitting for a few days I think it's going to be normar for this oil to drain back to the pan. As for the plug, I would stay away from the O-ring and go with the copper or fiber gasket as suggested earlier. I believe the pan and plug are designed to take a flat gasket, not a round o-ring.
