JCB 214 series 3 transmission 1998
Bob Olson
PostPosted: Tue May 01, 2007 6:56 pm    Post subject: JCB 214 series 3 transmission 1998 Reply to specific post Reply with quote
Looking for anyone who has had a overheating and shift problem .
After about a hour of operation the transmission will not shift and
feels as the transmission is locking up.
The transmission fluid has been changed and filter replaced but
seems to overheat still.
I also notice transmission fluid coming out the trans fluid fill.
Please help.
AJK
PostPosted: Tue May 01, 2007 11:24 pm    Post subject: Re: JCB 214 series 3 transmission 1998 Reply to specific post Reply with quote
Sounds to me as if the oil pressure is going low as the machine warms up,the cooler for the transmission is in front of the rad,it and the rad need to be clean,look to see that the fan is intact,has no broken blades,the belt is not slipping,the trans fluid is checked with the engine on low idle,there is a washable suction strainer for the trans fluid,its under a oval plate near the spin on filter,there is a quick break test point there as well,have a look at the strainer and it will be a good indicator of what going on inside,if the strainer is not blocked put it back and have the pressure tested,you should find out what's wrong rather than use it because if the pressure is low and not engaging the clutches properly they will be slipping and that will cause excessive wear,the pump may need replacing.
AJ
