TORK SPEC FOR INT 500 4 CYL DIESEL DOZER
ROSCO50
Guest
PostPosted: Tue May 08, 2007 11:13 pm    Post subject: TORK SPEC FOR INT 500 4 CYL DIESEL DOZER Reply to specific post Reply with quote
I HAVE A INTERNATIONAL 1969 500C DOZER WITH A 4 CLY DIESEL DOES ANYBODY KNOW THE TORK SPEC THE ROD BOLTS AND HEAD BOLTS AND THE MAIN BOLTS
CHinNY
Guest
PostPosted: Wed May 09, 2007 3:45 am    Post subject: Re: TORK SPEC FOR INT 500 4 CYL DIESEL DOZER Reply to specific post Reply with quote
A 500C would have a 3 cylinder in it
ROSCO50
Guest
PostPosted: Wed May 09, 2007 8:39 pm    Post subject: Re: TORK SPEC FOR INT 500 4 CYL DIESEL DOZER Reply to specific post Reply with quote
SORRY I WAS TOLD IT WAS A 500C IM REBUILDING THE MOTOR AND I NEED THE TORQ SPECS
Milton
Guest
PostPosted: Thu May 10, 2007 11:57 am    Post subject: Re: TORK SPEC FOR INT 500 4 CYL DIESEL DOZER Reply to specific post Reply with quote
There was a 3 cylinders motor (German) and a 4 cylinders motor (Britian) in that 500C crawler.
Milton
Milton
Guest
Milton
ben brown
Guest
PostPosted: Thu May 10, 2007 3:00 pm    Post subject: Re: TORK SPEC FOR INT 500 4 CYL DIESEL DOZER Reply to specific post Reply with quote
head 75-80 ft lbs rod 40-45 ft lbs main bearing pitch bolt it is a bolt thred larger then shank. place bolt 80-85 shank and tread dia. are the same this torque game from bookon b 414 2444 2424 all with bd 154 engine and that should be wht you have as the earlt 500 serie used the 4 cly.
ROSCO50
Guest
PostPosted: Thu May 10, 2007 8:08 pm    Post subject: Re: TORK SPEC FOR INT 500 4 CYL DIESEL DOZER Reply to specific post Reply with quote
OK THANKS BUT YOU LOST ME ON THE SHANK WHAT DO YOU MEAN place bolt 80-85 shank and tread dia
ben brown
Guest
PostPosted: Fri May 11, 2007 5:25 pm    Post subject: Re: TORK SPEC FOR INT 500 4 CYL DIESEL DOZER Reply to specific post Reply with quote
if you have pitch bolts 75-80 ft lbs.pitch bolts have a smaller shank running from head to thread then the treads are a larger diamenter. place bolts shank same diamenter from head to end of tread on thies bolts 80-85 ft lbs. i would probley tork. to 80 ft for eather style
ROSCO50
Guest
PostPosted: Fri May 11, 2007 9:00 pm    Post subject: Re: TORK SPEC FOR INT 500 4 CYL DIESEL DOZER Reply to specific post Reply with quote
OK THANKS
