Author |
Message |
John M Tractor Guru
Joined: 04 Feb 1999 Posts: 9263 Location: Gray Court, SC
Posted: Mon Sep 02, 2019 7:08 am Post subject: Stumped on Carb |
Its been 2 years now, and no matter what we have done to this carb, it simply will just not cooperate. Its been apart like 6 times, cleaned, gone through, put back together and it still acts up. The stupid needle keeps sticking closed, and it just doesnt get enough fuel. Weve tried new needles and seats, old needles and seat, even one brass we just happen to find. We modified seats, done anything and everything we can think of to do, and it just simply wont stay running. This week it did run for about an hour straight with no problems. (That needle ad seat came from an H.) Now its back to only running a few minutes. We thought the line might be a problem, so I changed all of that this morning, nope. Pulled the bottom off the carb and the needle is again stuck in the seat. For temp measures we rigged up a tank, needle stil sticks. Im seriously starting to think something is wrong woth the top of the carb making the needle sit cockeyed or something. ANy sugggestions before Mr Avery (My neighbor who owns it.) buys a new carb for the thing? |
Back to top |
Janicholson Tractor Guru
Joined: 30 Jan 2004 Posts: 36314 Location: St. Cloud, MN
Posted: Mon Sep 02, 2019 7:41 am Post subject: Re: Stumped on Carb |
The two ideas I have might help. #1 the tiny tab of brass that lifts the needle can have a wear spot on it that pushes the needle crooked. It can be filled in, or flattened (or replaced with a new float) to fix this (seen it many times). #2 the needle is too tight, or loose, in the seat, and gets stuck. I have used abrasive paper to polish off the triangle edges to make it looser, and also used needles from different carbs to make it fatter. Cutting off and polishing a dome on the new needle by putting it in an electric hand drill !!! Jim |
Back to top |
John M Tractor Guru
Posted: Mon Sep 02, 2019 8:57 am Post subject: Re: Stumped on Carb |
Its got the carb from my M on it now and its purring right along. I wish Mr Avery would get something lower to the ground, but he loves his Ms. I have put multiple needles and seats in this carb. The one that worked the bast was from an old H he sold 2 years ago. (The man keeps everything.) It worked fine for about 30 minutes or so. The float I know is good, it was mine. His son is coming down this evening with another carb that will have to be rebuilt most likely, so at least he wont have to buy a new one. I still think something is wrong with this top. |
Back to top |
Roger Tomfohrde Long Time User
Posted: Mon Sep 02, 2019 9:13 am Post subject: Re: Stumped on Carb |
Have you checked the float for rubbing on the side? I have tipped the carb over during assembly with it dry. Guy blew into the inlet to make sure it seats. And then flipped it over to hear if it was moving freely. |
Back to top |
Posted: Mon Sep 02, 2019 10:43 am Post subject: Re: Stumped on Carb |
If the top was rethreaded at the seat threads, it could be crooked? Jim |
Back to top |
John M Tractor Guru
Posted: Mon Sep 02, 2019 11:06 am Post subject: Re: Stumped on Carb |
Yep. Its the needle that keeps hanging up. Ive tore the whole carb down with the needle staying stuck in the seat. Ive bored out the seat, filed down the needle, used other needles and seats, etc. Mr Avery has been running it with my carb for close to 3 hours now, not one hiccup. This old M hasn't ran this long on many years. He used it on and off for his garden since 96 or so, and then started using his H. He sold the H a couple of years ago, and pulled the M out a couple of years ago and its been acting up since. |
Back to top |
John M Tractor Guru
Posted: Mon Sep 02, 2019 11:09 am Post subject: Re: Stumped on Carb |
Thought about that. It looks OK, but it could just be off enough to cause it bind, I suppose. The seat looks to be seating fully on the body. |
Back to top |
caterpillar guy Tractor Guru
Posted: Mon Sep 02, 2019 1:49 pm Post subject: Re: Stumped on Carb |
Take the needle with the steel tip and with it in the seat tap it with a small hammer to make it fit the seat better and try . At this time it is no loss. There was a guy near here that did that with all the carbs he rebuilt to set the needle to the seat. |
Back to top |
Posted: Mon Sep 02, 2019 2:28 pm Post subject: Re: Stumped on Carb |
So the ones in my 560 have a little spring clip that will pull the needle out if it is too low. At least it should as tightly it is in place. |
Back to top |
Gary Mitchell Tractor Expert
Joined: 05 Jun 2000 Posts: 1910 Location: St Clair Co. Missouri
Posted: Tue Sep 03, 2019 7:58 am Post subject: Re: Stumped on Carb |
After making sure the intake manifold is good I'd probably toss that carb and get another one, however, you might try a cheap, low pressure electric fuel pump. gm |
Back to top |
rustyfarmall Tractor Guru
Posted: Tue Sep 03, 2019 9:03 am Post subject: Re: Stumped on Carb |
There is contaminants in the fuel tank. Remove the tank and do a thorough cleaning. |
Back to top |
John M Tractor Guru
Posted: Tue Sep 03, 2019 10:20 am Post subject: Re: Stumped on Carb |
Nope. Its really clean, which really surprises me. I had originally thought a leaf or something was in there, but we flushed it
several times and never got anything out, and the times we have pulled the sediment bulb out there is never nothing in the outlet.
In fact, yesterday when it was actng up, I was able to pull the fuel line off before it died and gas flowed freely. Stuck line
back on and it still acted the same. |
Back to top |
John M Tractor Guru
Posted: Tue Sep 03, 2019 10:21 am Post subject: Re: Stumped on Carb |
Ms dont have that clip. |
Back to top |
Posted: Tue Sep 03, 2019 11:09 am Post subject: Re: Stumped on Carb |
CVPost-John M wrote: | (quoted from post at 11:20:55 09/03/19) Nope. Its really clean, which really surprises me. I had originally thought a leaf or something was in there, but we flushed it
It may look clean, but does it smell clean? Residue from old, stale fuel will cause a needle valve to stick faster than anything else I know of. |
Back to top |
D Slater Tractor Guru
Posted: Tue Sep 03, 2019 11:53 am Post subject: Re: Stumped on Carb |
Sounds like another carburetor is working okay. Just wondering has the tank been lined? If not a perfect job it can leach into the fuel and stick the needles. |
Back to top |
