Perkins AD3 152 diesel inframe rebiult
Goto page Previous  1, 2, 3  Next
ptfarmer
PostPosted: Tue Sep 10, 2019 7:41 pm    Post subject: Re: Perkins AD3 152 diesel inframe rebiult Reply to specific post Reply with quote
Jackangel wrote:
(quoted from post at 11:21:46 09/10/19)
Thanks for all your replies. So i hope my gently hand paper sanding in the spot shown in the picutre wont create any damage... :cry:
I don't think it will (on the spot you circled), if anything you only knocked down any tiny high spots, and some burrs along the edge.
Jackangel
PostPosted: Tue Sep 10, 2019 10:42 pm    Post subject: Re: Perkins AD3 152 diesel inframe rebiult Reply to specific post Reply with quote
Ok. Thanks to all.
I will go for Scothcx brite fine polishing then. Main issue are the gunk / marks on thge cyl#3 parent bore.. you can really feel the grooves by putting your finger on them..
I am not planning to replace the camshaft, or in your option should I go for a new one? The lift pump is correctly operated by this despite the pit caused by years of operation (7000hs)
I do think I ll be going for original PERKINS spares (finished liners), I shown the damaged piston #1 to a local MF / Perkins dealer and in his opinion that damage (cavity on the piston side and footprint on sleeve) has been generated by a faulty injector operations which does not spray correctly so to get an atomised flow
Back to head gasket I am asking if an non setting compote , as Hylomar Universal blue is, is suggested to be smeared over the new head gaskets. Also here your suggestion would be appreciated a lot!
ptfarmer
PostPosted: Wed Sep 11, 2019 6:17 am    Post subject: Re: Perkins AD3 152 diesel inframe rebiult Reply to specific post Reply with quote
You really can't do anything about the grooves, I would just clean it up a bit with scotch brite. Scotch brite is only going to remove anything that is already loose which is all you need to really do.
ptfarmer
PostPosted: Wed Sep 11, 2019 6:27 am    Post subject: Re: Perkins AD3 152 diesel inframe rebiult Reply to specific post Reply with quote
Depending on what the head gasket is made of the instructions should say if you are to use a sealer on it.
Jackangel
PostPosted: Wed Sep 11, 2019 6:45 am    Post subject: Re: Perkins AD3 152 diesel inframe rebiult Reply to specific post Reply with quote
you mean scotch brite equivalent >1000 grit?
I am purchasing genuine PERKINS head gasket.. should be copper made.. so I think putting some non setting sealant would no be harmful...
what about camshaft pit at lift pump?
ptfarmer
PostPosted: Wed Sep 11, 2019 5:42 pm    Post subject: Re: Perkins AD3 152 diesel inframe rebiult Reply to specific post Reply with quote
If you replace the camshaft then you have to replace the lifters also, the cam lobes, and lifters have to bed into each other. Old lifters on a new can either wear the cam lobe (or the lifter) out quick.
Jackangel
PostPosted: Thu Sep 12, 2019 12:41 am    Post subject: Re: Perkins AD3 152 diesel inframe rebiult Reply to specific post Reply with quote
Thank you Ptfarmer for answering. So I ll keep this camshaft then.
As I am planning next step I am now really into the re-installation guidelines contained in the workshop manual.
- I would then put in the chiller the new service liners and use the flat bar as suggested. What about using the same puller pad I used for sleeving the old liners out?
- Conrod locking nuts. I see in the torques spec attached there are different settings according to nuts type (cadmium coated, phospateted).. which ones does my engin run according to this picture?
- Conrodss report the code 31337540 and a wording NAW with a code I cannot clearly read.. I do guess they are OEM ones.
- I am also replacing the conrods small end bushes as well as gudgeon pins I ll just press them out? Any suggestion on alternative methods or tips?
- Once I ll have fitted new service liners it I am check the relation of them to top face of bock which is specified to be + / - 0,004" (0,1mm) should it be better to have them up / down in relation to block surface?
ptfarmer
PostPosted: Thu Sep 12, 2019 7:53 am    Post subject: Re: Perkins AD3 152 diesel inframe rebiult Reply to specific post Reply with quote
I wouldn't use the puller, you need the flat bar that covers all the top of the sleeve. If the sleeves are chilled enough they might (but rarely) go all the way in on their own but I'd have the flat bar ready.
On the liners my MF shop manual says Flush to 0.004 in below the deck for the ad3.152.
As for as the rod nuts I would see about getting new ones since they are self locking nuts.
After pressing in the new bushings in the rods they will probably need to be reamed to size for proper clearance to the wrist pin.
Jackangel
PostPosted: Thu Sep 12, 2019 12:24 pm    Post subject: Re: Perkins AD3 152 diesel inframe rebiult Reply to specific post Reply with quote
Thx again :wink:
Got the point of the flat bar and i ll do so
By googling i found out my nuts are cadmium plated version..
I do not see any lip nor flange in them and they came out smmotlhy all the way so i thought they were not self locking..
Can i leave the sleeve chilling for some days or is it bad?
ptfarmer
PostPosted: Thu Sep 12, 2019 8:20 pm    Post subject: Re: Perkins AD3 152 diesel inframe rebiult Reply to specific post Reply with quote
You can let the sleeves chill as much as you want, they are only going to get so cold. You may want to keep a eye on the sleeves while they are chilling just to make sure they don't start to possibly rust. If you can get a ice chest with some dry ice to chill the sleeves the dry ice will get them colder than a freezer will unless you have a really good freezer (which can help them go in easier).
Jackangel
PostPosted: Thu Sep 12, 2019 11:59 pm    Post subject: Re: Perkins AD3 152 diesel inframe rebiult Reply to specific post Reply with quote
LOL the freezer i've have is the one for the beef :lol: :lol:
I'll look for dry ice then...
I did not know small end bushes do not come already to size.. :(
Jackangel
PostPosted: Fri Sep 13, 2019 6:00 am    Post subject: Re: Perkins AD3 152 diesel inframe rebiult Reply to specific post Reply with quote
... then how do i polish the head - valve seats? scotch brite also here?
ptfarmer
PostPosted: Fri Sep 13, 2019 7:59 am    Post subject: Re: Perkins AD3 152 diesel inframe rebiult Reply to specific post Reply with quote
When you press the bushings in they get a little smaller on the inside. On the combustion chambers in the head I would wire wheel all the carbon off, then I would take the all the valves, and lap them to make sure that they still set good in the valve seats so they seal good.
Jackangel
PostPosted: Sun Sep 15, 2019 11:14 pm    Post subject: Re: Perkins AD3 152 diesel inframe rebiult Reply to specific post Reply with quote
Hi,
thanks a lot Ptfarmer for your suggestion.
I did use a hand wire stainless steel wire very thin wool and got this result, this wire wool is the one used for old wood furniture renovation. It just takes or the dirt with no marks on the metal. Hence I would also use this for polishing the block can it work?
Here some pictures
I then checked the head straightness with a sliding caliper bar and a gauge feeler and the 0,05mm sheet does not slide under it nor length nor wide side so I assume more or less the head is correct.
I also measure the thickness and it turned to be 76,2mm while the engine manual states 75,82mm/76,58mm (2,985/3,015 in)
Question: How can I see where it was already decked/grinded? The head gasket does not report any numbers (i.e. tolerances) but just the wording "MADE IN ENGLAND" and FRONT TOP). Then the manual reports that shims are used under the injectors to adjust their protrusion inside the chamber. As long as I have not found any of them I guess it was not machined.
Liners Fitting: I forgot to ask whether smearing LOCTITE or any similar bonding around the outer surface of the new liners is suggested or not. I am not a real fan of this chemicals. Really..
thanks to you all
Jackangel
PostPosted: Mon Sep 23, 2019 3:45 am    Post subject: Re: Perkins AD3 152 diesel inframe rebiult Reply to specific post Reply with quote
Hi all,
did manage to sleeve new liners in after getting them frozen for 10/12 hours and using a flat bar + the puller pads to drive them in place with a threaded rod (opposite sequence of what I did when policing them out ).
Had the recessed measured on 4 points for each liner and it turned to be 0,04mm almost everywhere.
I have not used LOCTITE on the new sleeves outer surface but just smearing some 10W40 oil in the parent bores. The AD 3 152 workshop manual says LOCTITE to be used only on service PLAIN liners but not on those flanged.
Here s new head gaskets, from an accurate check and measurements it seems the head has already been decked at some stage, local MF spare dealer says using standard head gasket is ok, I thought PERKINS had greater thickness head gaskets according to new head height after decking / resurfacing.
Would you use HYLOMAR universal to install new head gaskets?
I also changed conrods small end bushes. New ones have 4,5mm hole for oil passage while old ones was 5,5mm
Put rings on new pistons and have them mounted inside new sleeves, torqued down the conrods nuts and now waiting to go on
I noticed no the crank is A LOT harder to rotate by hand.
Page 2 of 3
