Perkins AD3 152 diesel inframe rebiult
Goto page Previous  1, 2, 3
ptfarmer
PostPosted: Mon Sep 23, 2019 6:46 am    Post subject: Re: Perkins AD3 152 diesel inframe rebiult Reply to specific post Reply with quote
The amount they remove when you have a block or head resurfaced isn't very much to worry about. On the head gasket I like to use Permatex Copper Spray-A-Gasket, other mechanics recommendations may vary on what to use or not.
Jackangel
PostPosted: Tue Sep 24, 2019 2:29 am    Post subject: Re: Perkins AD3 152 diesel inframe rebiult Reply to specific post Reply with quote
Hi,
I did a little bit of research on the web and I I found a lot of topic arguing about the use of any compound / sealants on head gasket.
I do think my new PERKINS genuine head gasket is copper (it seems multylayers though ) and jointing compounds are not to be used on MLS gaskets.
Anyhow my workshop manual states:
Therefore being my engine AD 3 152 (CE21899 lot ) produced in UK in 1978, which procedure should I comply with?
I did also find a topic here in yt I am replying to, the manual seems different to mine..
ptfarmer
PostPosted: Tue Sep 24, 2019 6:20 pm    Post subject: Re: Perkins AD3 152 diesel inframe rebiult Reply to specific post Reply with quote
My brother replaced the head gasket with another copper gasket on his MF150 (it has the AD3.152) this was before the spray on Permatex copper gasket sealer was ever available. Back then he used the old aluminum spray paint trick, all these years later it's still holding.
Jackangel
PostPosted: Tue Sep 24, 2019 10:55 pm    Post subject: Re: Perkins AD3 152 diesel inframe rebiult Reply to specific post Reply with quote
I see! My gaskets is copper outside layers and it seems to be made by foils...
Jackangel
PostPosted: Thu Sep 26, 2019 6:17 am    Post subject: Re: Perkins AD3 152 diesel inframe rebiult Reply to specific post Reply with quote
Hi again,
I was just re-assembling the oil sump by using a hydr jack and thread small bar for guiding and find a couple of threaded holes in the fly wheel plate where no setscrews/nuts were in
Were these holes drilled form manufacturing purposes perhaps?
Then I got another question for first start up after this in-frame rebuild: as I removed all the oil pipes they are now empty, should I first crank the engine with shut off fuel line to let the oil pump fill them in? Should I use a special oil for first start?
thansk
ptfarmer
PostPosted: Thu Sep 26, 2019 10:52 am    Post subject: Re: Perkins AD3 152 diesel inframe rebiult Reply to specific post Reply with quote
I would crank the engine over without the injectors in the head (so there is no real load on anything) until I see good oil pressure. Then I would put the injectors in, bleed it, then run it.
Jackangel
PostPosted: Thu Sep 26, 2019 10:06 pm    Post subject: Re: Perkins AD3 152 diesel inframe rebiult Reply to specific post Reply with quote
thanks pt for the suggestion, I'll do so.
Got the sump on, it was not that easy but did it. New front/rear gasket are cork made (put aviation sealant on them) while the old ones were silicone type rubber made.. (non OEM???)
New ones
Old ones
Jackangel
PostPosted: Tue Oct 01, 2019 4:12 am    Post subject: Re: Perkins AD3 152 diesel inframe rebiult Reply to specific post Reply with quote
Hi, so I put everything together and now engine is up and running aging with no more blow by nor smoke.
At the end of the day I smeared the new head gasket with as thin film of Hylomar non setting compound mentioned in the manual.
Got a question now: my workshop manual states to torque the head bolts down again @ 95Nm when engine is hot (coolant > 170F). I have not done it yet as I had the engine running for a 60/70mins only should I do it and it is better run it for few hours first? I must say I ve re used the old nuts and setscrews
So I again thank your for reading my posts and helping me out in suggesting what to do now I ll move on front wheels spindle bushings overhaul!
ptfarmer
PostPosted: Tue Oct 01, 2019 7:20 pm    Post subject: Re: Perkins AD3 152 diesel inframe rebiult Reply to specific post Reply with quote
I retorque the head once it get to operating temperature for the first time, I wouldn't run it for a few hours before retorquing. Using the old nut's, and screws should be ok unless the manual says otherwises.
Jackangel
PostPosted: Tue Oct 01, 2019 11:01 pm    Post subject: Re: Perkins AD3 152 diesel inframe rebiult Reply to specific post Reply with quote
thanks pt... I will do this when temp gauge has reached the green area in the gauge dashboard then.. manual say to do it when hot.. I am afraid this could hurt the threads...
ptfarmer
PostPosted: Wed Oct 02, 2019 5:02 am    Post subject: Re: Perkins AD3 152 diesel inframe rebiult Reply to specific post Reply with quote
Jackangel wrote:
(quoted from post at 00:01:45 10/02/19)
It won't hurt the threads.
Jackangel
PostPosted: Wed Oct 02, 2019 10:54 pm    Post subject: Re: Perkins AD3 152 diesel inframe rebiult Reply to specific post Reply with quote
Thank you.
So I did run it for 30mins to get 80C coolant temp and re-torqued the head down when hot..
I was surprised since some of the set screws needed almost a half a turn to be re-tightened to 95Nm.
No, manual does not specify new set screws should be used anytime you take the head off but it states indeed in my case head should be re-torqued after 25/50hs being my AD3 152 not one among the last ones with head fasteners with integral washer.
Is it common they needed to go half a turn in only after a 30mins running?
Page 3 of 3
