Erickson Farms !!
John Saeli
PostPosted: Thu Aug 29, 2019 4:17 am    Post subject: Erickson Farms !! Reply to specific post Reply with quote
Any progress with the 4890?
EricksonFarms
PostPosted: Fri Aug 30, 2019 3:15 pm    Post subject: Re: Erickson Farms !! Reply to specific post Reply with quote
That one doesn't have PTO, but I do think it is the that valve on the left side of the frame at the rear where the PTO would be controlled from if it had one, thoughts?
John Saeli
PostPosted: Sat Aug 31, 2019 4:42 am    Post subject: Re: Erickson Farms !! Reply to specific post Reply with quote
The valve I believe you reference, upper left in the back, had a line running up the PTO that pressurized and engaged the PTO brake when the PTO was disengaged. I disconnected the line and installed a pipe plug in the valve. Cured the problem we had, that sounds very much like the problem you are having. Even though this tractor has no PTO unit, is the plumbing there? The line was small, maybe 1/4", and came out the right side of the valve.
Is the Power Shift affected?
EricksonFarms
PostPosted: Mon Sep 09, 2019 3:27 pm    Post subject: Re: Erickson Farms !! Reply to specific post Reply with quote
We took the value body's off the back of the tractor. No the powershift seems to be all ok, I'll send you some pics of what I think is the issue when I get back to it, we have alot of field work to do before I can get back to it
