davis 102 hydraulic pump
wildwilf
PostPosted: Tue Sep 10, 2019 3:37 pm    Post subject: davis 102 hydraulic pump Reply to specific post Reply with quote
Hello
Does anyone know where I can get the pump body part # 400297m1 is the Massey # or a pump for this loader
Or if the one they sell here will work Part No: 40P018LAJSA
Wilf
shinnyboots
PostPosted: Thu Sep 12, 2019 7:33 am    Post subject: Re: davis 102 hydraulic pump Reply to specific post Reply with quote
u might check surpluscenter.com they have gear pumps
ptfarmer
PostPosted: Thu Sep 12, 2019 8:06 am    Post subject: Re: davis 102 hydraulic pump Reply to specific post Reply with quote
CVPost-shinnyboots wrote:
(quoted from post at 08:33:30 09/12/19) u might check surpluscenter.com they have gear pumps
X2 ^^^^^^^^^^^^^^^^^^
wildwilf
PostPosted: Thu Sep 12, 2019 5:23 pm    Post subject: Re: davis 102 hydraulic pump Reply to specific post Reply with quote
I have figured out the L827-10X-LB pump mounts the same and has the same shaft it is just less gallons per minute.
So I going to try it
Wilf
ptfarmer
PostPosted: Thu Sep 12, 2019 9:20 pm    Post subject: Re: davis 102 hydraulic pump Reply to specific post Reply with quote
wildwilf wrote:
(quoted from post at 18:23:28 09/12/19) I have figured out the L827-10X-LB pump mounts the same and has the same shaft it is just less gallons per minute.
Wilf
How much less gallons per minute, less gpm the slower the loader will work.
wildwilf
PostPosted: Fri Sep 13, 2019 5:05 am    Post subject: Re: davis 102 hydraulic pump Reply to specific post Reply with quote
It runs 14gpm in stead of 17
ptfarmer
PostPosted: Fri Sep 13, 2019 7:46 am    Post subject: Re: davis 102 hydraulic pump Reply to specific post Reply with quote
14 gpm is the minimum I'd use on a FEL.
wildwilf
PostPosted: Fri Sep 13, 2019 6:19 pm    Post subject: Re: davis 102 hydraulic pump Reply to specific post Reply with quote
I'm just hoping that it works right I will post the results after I get it on.
wildwilf
PostPosted: Fri Sep 27, 2019 9:50 am    Post subject: Re: davis 102 hydraulic pump Reply to specific post Reply with quote
Well the L827-10X-LB hydraulic pump works great on my 63 MF 202 ind.
A couple things that will need to change
the mounting bolts to 7/16 x 1 1/4, also had to change the plumbing configuration on the filter.
It might run a bit slower but nothing that is really noticeable.
I hope this helps other people, I know I had a real B@#$% of a time finding one that would work.
