MF 204 loader needs hydraulic hose repair
Goto page Previous  1, 2
Jim.ME
PostPosted: Thu Sep 12, 2019 2:59 am    Post subject: Re: MF 204 loader needs hydraulic hose repair Reply to specific post Reply with quote
I am glad that male O-ring boss adapter worked for you. However it should be noted the sealing point of it is completely different from the original. The valve body does not have the proper sealing surface for the O-ring. There is supposed to be a specific smooth chamfer area, above any threads, for the O-ring of the male boss fitting to seat in that I believe is not there on your valve body, where the hole is tapped for the original fitting which seals at the O-ring down inside the valve body. How well this works out on a given hole is subject to the condition of the top area of each hole. Again glad it is working for you.
a.bourbon@comcast.net
PostPosted: Thu Sep 12, 2019 3:20 am    Post subject: Re: MF 204 loader needs hydraulic hose repair Reply to specific post Reply with quote
Thanks for all the great help. I just ordered an exact replacement hose from an MF dealer part number 705441M91. Wish I had seen this post earlier, would have saved me a lot of money.
Jim.ME
PostPosted: Thu Sep 12, 2019 3:41 am    Post subject: Re: MF 204 loader needs hydraulic hose repair Reply to specific post Reply with quote
Yes it cost more than a patch, but you made the correct and proper repair. Less risk of a leak or failure than changing the designed sealing point.
Save your old hose for a time. You can now look around for or order a braze type stem to put the old end on to, or to check with hydraulic shops (or to search the web) to find proper fitting so you will have a spare end fitting ready for the future. I would try to find something local so the fitting would match the suppliers hose making equipment.
Page 2 of 2
