Truck hardware question
JDEM
PostPosted: Thu Sep 12, 2019 5:55 am    Post subject: Truck hardware question Reply to specific post Reply with quote
I have a 2008 Ford truck I bought recently. Something has me a little perplexed.
I found both links on the rear stabilizer bar broken. They were OEM from Ford. Ford used a 10 MM bolt, grade 8.8. Pretty much the same tensile strength as a US grade 5.
Since both the originals broke right in two I am thinking it might be good to use something stronger? I have no history on this truck but it certainly does not look like it was ever used hard or off-road.
So I ordered what appeared to be a HD option in the aftermarket - from Delco Professional. I opened the box and these come with US bolts that are 3/8" and grade 5. So if anything, a bit weaker then what Ford used OEM.
Am I missing something here in the engineering? I am tempted to just go out and buy some 3/8" bolts that are grade 8 unless I discover there is a reason not to?
I checked 5 different brands of rear link kits and none have bolts any stronger then what Ford used OEM.
Russ from MN
PostPosted: Thu Sep 12, 2019 6:31 am    Post subject: Re: Truck hardware question Reply to specific post Reply with quote
Where will the next weakest link be? Sounds like something is wrong or just some bad engineering. Maybe the Delco parts are the solution!
M-MAN
PostPosted: Thu Sep 12, 2019 6:39 am    Post subject: Re: Truck hardware question Reply to specific post Reply with quote
I have never seen one broke. My guess is someone hit some big holes hard and they snapped just like a tractor spindle.
Steve@Advance
PostPosted: Thu Sep 12, 2019 7:05 am    Post subject: Re: Truck hardware question Reply to specific post Reply with quote
Wonder if it got improperly tied down on a transport or roll off?
Sprint 6
PostPosted: Thu Sep 12, 2019 7:10 am    Post subject: Re: Truck hardware question Reply to specific post Reply with quote
The links are likely designed to break before something else more expensive does. Like the sway bar, or the control arm attaching point. I would go back with what was there. 11 years likely had the bolts rust weakened.
ss55
PostPosted: Thu Sep 12, 2019 9:15 am    Post subject: Re: Truck hardware question Reply to specific post Reply with quote
I've had links to front stabilized bars break on vehicles I bought used. The stabilizer bars were not damaged. The links were inexpensive, easy to replace and OEM replacements never broke again. If the price is reasonable, I would stay with EOM parts to avoid breaking something more expensive.
DR. EVIL
PostPosted: Thu Sep 12, 2019 4:22 pm    Post subject: Re: Truck hardware question Reply to specific post Reply with quote
Had an '87 F-150 with frt & rear sway bars, links on one end of each bat broke due to excessive rust. '88 Mustang GT had frt & rear sway bars too, broke one link on each bar. Once one link breaks, all the stress is relieved from the other link.
Don't think I would put the Delco parts on, use the OEM replacements.
fastfarmall
PostPosted: Thu Sep 12, 2019 5:05 pm    Post subject: Re: Truck hardware question Reply to specific post Reply with quote
Hi Steve,i have heard story's about that also! The first time was when the 58 Chevy were tied down wrong, well any way they changed there method, of how they got tied down after that fiasco !
BigPapa53
PostPosted: Thu Sep 12, 2019 5:17 pm    Post subject: Re: Truck hardware question Reply to specific post Reply with quote
Ford sway bar links are well known for breaking, especially if you do any kind of off-roading on uneven terrain like terraces, ditches, and creek banks. Anything that flexes the suspension. Off-roaders looking for better articulation get links that can be disconnected by pulling a pin for full travel.
Hobo,NC
PostPosted: Thu Sep 12, 2019 5:34 pm    Post subject: Re: Truck hardware question Reply to specific post Reply with quote
Delco Professional is just another cheap china supplier...
fusion
PostPosted: Fri Sep 13, 2019 4:43 am    Post subject: Re: Truck hardware question Reply to specific post Reply with quote
Put the OEM bolts in and forget about
Ford Dealer Bob
