Ford 3000 mystery transmission
Goto page 1, 2  Next
Thelumberwagon
PostPosted: Sun Sep 15, 2019 12:56 pm    Post subject: Ford 3000 mystery transmission Reply to specific post Reply with quote
I'm looking at a Ford 3000 for sale with a brush hog for $1000. From what I can tell it's a 1969. I'm puzzled by the transmission. It's only got one shifter and there is another boot (about the size of the shifter boot but with a 90 degree angle) on top of the transmission cover that has electrical wires coming from it and going into the engine compartment. Before I buy this, I want to make sure This isn't some oddball tractor that I should avoid. The tractor needs some work and front tires but it's got front and rear weights and I figure for $1000 I can't really go wrong...can I?
I've scoured the net for some information on the transmission but all I find are dual shifters and SOS.
Any help would be very appreciated.
Bern
PostPosted: Sun Sep 15, 2019 1:13 pm    Post subject: Re: Ford 3000 mystery transmission Reply to specific post Reply with quote
One shift lever would make it a 4-speed transmission. That would be quite rare on a 3000 I would think.
4 speed
3000OH
PostPosted: Sun Sep 15, 2019 1:36 pm    Post subject: Re: Ford 3000 mystery transmission Reply to specific post Reply with quote
Rare and not very desirable or usable or valuable in my opinion.
Ultradog MN
PostPosted: Sun Sep 15, 2019 1:43 pm    Post subject: Re: Ford 3000 mystery transmission Reply to specific post Reply with quote
4 speed transmissions are not uncommon
on the 2000 and 3000 tractors.
Especially on the earliest ones.
But I don't get this right angle shifter
deal. Ford did offer an auxiliary
transmission like the old Sherman Combos
but those had a separate shifter on the
Left side of the bell housing.
They also offered a 4 speed shuttle
shift on some of the industrial models
built on that platform but I don't think
they could have a pto and the shifter
was on the dash.
A photo of the shifter would help a lot.
Assuming it runs and mows as is I would
say the price is dirt cheap, especially
with the weights and the mower. Those 3
bangers are some great, reliable old
machines.
Mike(NEOhio)
PostPosted: Sun Sep 15, 2019 1:47 pm    Post subject: Re: Ford 3000 mystery transmission Reply to specific post Reply with quote
Wires from the neutral switch?? So you can't start it in gear.
Ultradog MN
PostPosted: Sun Sep 15, 2019 2:01 pm    Post subject: Re: Ford 3000 mystery transmission Reply to specific post Reply with quote
Not so rare, at least in these parts.
And not so unuseable imo. My first 3 cyl Ford was a plain Jane 2000 gasser w/4 speed.
I owned it for about 4 years and did a lot of work with it - plowing, discing, finish mowing, brush hogging - the usual stuff with it.
Yes, 1st gear is very fast and no way would I trade my 8 speed w/live power for one. But I liked the tractor a lot more than the N Series and a 641 I'd had before that. And if given the choice between that 4 speed and an SOS I'd take the... Well I'd better not say that here.
Bern
PostPosted: Sun Sep 15, 2019 3:24 pm    Post subject: Re: Ford 3000 mystery transmission Reply to specific post Reply with quote
You must really hate the SOS with a passion to prefer a 4 speed over it.
Fordfarmer
PostPosted: Sun Sep 15, 2019 3:50 pm    Post subject: Re: Ford 3000 mystery transmission Reply to specific post Reply with quote
You should have read his craigslist ad for the SOS after he pulled it out of his 4200! 😄
Thelumberwagon
PostPosted: Sun Sep 15, 2019 4:22 pm    Post subject: Re: Ford 3000 mystery transmission Reply to specific post Reply with quote
Here are some pics of the shifter and electrical boot. Is this just a standard 4 speed? I'm only going to use it for mowing.
JoeM(GA)
PostPosted: Sun Sep 15, 2019 4:41 pm    Post subject: Re: Ford 3000 mystery transmission Reply to specific post Reply with quote
it's a "C10" so it's a 3000, and you can see the "A" at the far end of the model code A ? 4x1 speed manual,
I bet it was a state or county bid tractor
Thelumberwagon
PostPosted: Sun Sep 15, 2019 5:00 pm    Post subject: Re: Ford 3000 mystery transmission Reply to specific post Reply with quote
Just a standard 4 speed...dang...oh well.
As far as I can tell, it needs the starter rebuilt and some new fronts. Then I can really assess it. The guy said it may need brakes too but I can't afford to buy one that doesn't need work. However, I can afford a fixer upper like this. The brush hog is a 5 ft and seems to be in decent order.
I've tried to do some research to determine things I should look for specifically that would steer me away from it. I value the advice from the forum and anything you throw my way is always welcome.
It should be a good mower and maybe something I could use a backboard on shouldn't it?
Fordfarmer
PostPosted: Sun Sep 15, 2019 5:34 pm    Post subject: Re: Ford 3000 mystery transmission Reply to specific post Reply with quote
Yes, 4-speed and the boot is for the
neutral safety switch.
Bern
PostPosted: Sun Sep 15, 2019 5:57 pm    Post subject: Re: Ford 3000 mystery transmission Reply to specific post Reply with quote
Once you've driven an 8-speed, I don't know how you could tolerate a 4. It would drive me nuts.
Ultradog MN
PostPosted: Mon Sep 16, 2019 12:43 am    Post subject: Re: Ford 3000 mystery transmission Reply to specific post Reply with quote
Bern, The 4 speeds aren't the best transmission but they were simple and reliable.
This guy's plight is just one reason to not want one. If it was a failed clutch on a crash box it is a big job to do the split/replace but new parts are readily available for $150 or so.
To do this job on his SOS is a bigger job with a double split and he's forced to find used parts for a lot more money.
And then there's the issue of their complexity.
Add to that their lack of precision for tight manuvering and their very unpleasant hard shifting I really don't know why anybody would want one.
Mark,
Lol,
I was a little hard in them in that ad wasn't I.
Ultradog MN
PostPosted: Mon Sep 16, 2019 1:39 am    Post subject: Re: Ford 3000 mystery transmission Reply to specific post Reply with quote
I know I'm in the minority here but
having had 2 of those 4 speeds still say
it will do fine and the price is cheap -
again, if it will run and mow as is or
with just a little work.
No, it's not an 8 speed with live power.
But it is a good, reliable old machine
that will do a lot of useful work yet.
It will always be worth at least what
you paid for it even without the weights
and mower.
Heck, a lot of guys would be happy to
pay that much for an 8N on a package
deal like that. That is much better than
an N.
How about some photos of the rest of the
tractor?
Goto page 1, 2  Next
Page 1 of 2
