Ford 3000 Ford 3600 engine swap
Hooder
PostPosted: Mon Sep 16, 2019 4:57 pm    Post subject: Ford 3000 Ford 3600 engine swap Reply to specific post Reply with quote
How many modifications need to be done to put a Ford 3600 diesel engine into an older 3000 diesel ?
Fordfarmer
PostPosted: Mon Sep 16, 2019 5:23 pm    Post subject: Re: Ford 3000 Ford 3600 engine swap Reply to specific post Reply with quote
Will need the 3000's exhaust manifold, as
a 3600's exits farther forward. Keep the
flywheel from the 3000. (Flywheels stay
with their respective transmissions.)
Otherwise, should be a straight bolt in.
Bern
PostPosted: Mon Sep 16, 2019 5:25 pm    Post subject: Re: Ford 3000 Ford 3600 engine swap Reply to specific post Reply with quote
Not much. As I recall, one of the major differences is the size and angle of the opening in the intake
manifold. You cannot swap the manifolds, you'll need to adapt the hose. The exhaust manifold is also
different, but can be swapped between the two engines.
Bern
PostPosted: Mon Sep 16, 2019 5:26 pm    Post subject: Re: Ford 3000 Ford 3600 engine swap Reply to specific post Reply with quote
Why does the flywheel need to stay with the tranny? If they both have the double clutch, they should be the same.
Fordfarmer
PostPosted: Mon Sep 16, 2019 7:46 pm    Post subject: Re: Ford 3000 Ford 3600 engine swap Reply to specific post Reply with quote
If they use the same clutch, then yes, the flywheels should interchange.
