1965 Ford 2000 diesel blowing air from the air intake stack
Bart CA
PostPosted: Tue Sep 17, 2019 7:05 am    Post subject: 1965 Ford 2000 diesel blowing air from the air intake stack Reply to specific post Reply with quote
There is some air blowing from the air intake stack.
It seems fresh air no exhaust smell
It is supposed to be vaccuum at air intake.
Engine runs well good power no smoke.
Any ideas ?
Thanks in advance
Bart
Dieseltech
PostPosted: Tue Sep 17, 2019 8:46 am    Post subject: Re: 1965 Ford 2000 diesel blowing air from the air intake st Reply to specific post Reply with quote
On any engine that "pops back" on the intake side, I pull the valve cover and check all rocker arms. When an exhaust valve does not open as it should there will be trapped cylinder pressure that will then pop back through the intake side when that valve opens. Could be a too loose setting, push rod out of place, or a broken rocker.
sotxbill
PostPosted: Tue Sep 17, 2019 8:52 am    Post subject: Re: 1965 Ford 2000 diesel blowing air from the air intake st Reply to specific post Reply with quote
or intake valve too tight/burnt/damaged seat, and its blowing back on the compression stroke some or a lot.
Bart CA
PostPosted: Tue Sep 17, 2019 4:24 pm    Post subject: Re: 1965 Ford 2000 diesel blowing air from the air intake st Reply to specific post Reply with quote
Thank you both for your replies
Greatly appreciated !
Bart
David G
PostPosted: Tue Sep 17, 2019 6:02 pm    Post subject: Re: 1965 Ford 2000 diesel blowing air from the air intake st Reply to specific post Reply with quote
Does it pop loudly?
hightech1953
PostPosted: Thu Sep 19, 2019 7:57 pm    Post subject: Re: 1965 Ford 2000 diesel blowing air from the air intake st Reply to specific post Reply with quote
If it is just puffs of air I was told this was normal for a diesel.
