Hydraulic Pressure
Joel Sanderson
PostPosted: Thu Sep 19, 2019 7:12 am    Post subject: Hydraulic Pressure Reply to specific post Reply with quote
Anyone know how much pressure the number series has in its hydraulics? (60, 70, 80, 620, 720, etc.) I'll be putting an hydraulic pump on my D, under the mag, and I'm wondering how its pressure will compare to other tractors. I don't suppose it'd be the same basic pump, now would it? I should take a picture of it, but I've gotta go turn some hay. I can tonight if it'd help.
Is there any reason I can't use modern hydraulic oil (whatever that is) with it? My '44 A says 30 w oil, but I want the D to be compatible with the farm's implements that're run by the other tractors.
joel
Mike M
PostPosted: Thu Sep 19, 2019 7:19 am    Post subject: Re: Hydraulic Pressure Reply to specific post Reply with quote
Those old ones don't have very much pressure. I'd have to look in the books for sure so I'm just guessing now. The A,D ? 1000psi. The 50,60,80 might be like 1200 psi ? and then the later 620,720 were higher around 1500 psi ?
What are you planning to run with the D ? I know many guys can't even run new style hay rakes anymore with old tractors.
Pete in MD
PostPosted: Thu Sep 19, 2019 7:23 am    Post subject: Re: Hydraulic Pressure Reply to specific post Reply with quote
With the pump you're going to use behind the mag, the working pressure will be around 610 PSI and max relief pressure will be 750-790 PSI.
Yes you can use HyGard or other modern hyd. oil.
Joel Sanderson
PostPosted: Thu Sep 19, 2019 10:15 am    Post subject: Re: Hydraulic Pressure Reply to specific post Reply with quote
I'll be lifting an 8 foot disc and a plow, but I also hope that it'll be able to lift the ten foot Brillion seeder we plant hay with. It's got two packer rolls but two cylinders. We generally use the 80, but it doesn't make the corners well, especially when we plant back and forth. I also think it's too heavy, even with duals, because a field I planted last year looked nice and smooth after I'd fitted it, but after I seeded it--which I had to go over twice in order to plant the timothy--it had wheel tracks. I think the D will be about right, with duals--if it can lift the seeder.
Personally, I don't much like that seeder. It only has one seed box, no fertilizer, and the metering is ridiculously crude and inaccurate. My little 9 hole, horse drawn Superior drill does a much better job, but it's too small for anything but tiny fields. But that's rather off topic.
Mike M
PostPosted: Thu Sep 19, 2019 10:44 am    Post subject: Re: Hydraulic Pressure Reply to specific post Reply with quote
Might be better off with the 620 ?
buickanddeere
PostPosted: Thu Sep 19, 2019 1:12 pm    Post subject: Re: Hydraulic Pressure Reply to specific post Reply with quote
If it won't lift, use a hydraulic cylinder of larger diameter.
Joel Sanderson
PostPosted: Thu Sep 19, 2019 5:26 pm    Post subject: Re: Hydraulic Pressure Reply to specific post Reply with quote
Oh probably. But I think the D'll ride better but have only half as many jobs it can do. Some day I'll have a 620. That's just not today. :)
KJohnson92
PostPosted: Thu Sep 19, 2019 5:29 pm    Post subject: Re: Hydraulic Pressure Reply to specific post Reply with quote
You can use hygard either way, most everyone does even in original pumps. Works great and flows better in the cold. Plus the whole not mixing ND oil into your other stuff thing is wise I think.
John Deere D
PostPosted: Thu Sep 19, 2019 8:31 pm    Post subject: Re: Hydraulic Pressure Reply to specific post Reply with quote
Joel......
I ran a John Deere "D" styled with extensions on steel to pull a model "Krause 10' and later a Model Alteen" disc....10' (used at old machinery days later 1970's).....they are heavy. Our JD 730 Diesel pulled it with a 10'section of 160 railroad iron...160 lbs /yard...dragging behind as a leveler.
My JD "R" pulled the same disc in 2 nd gear... the smoke rolled from the exhaust pipe (in the high 30's F at night) fire was evident from the stack, with no railroad iron behind it.
The hydraulics ...given they were probably on the low end of their factory maximum out put,(PSI) required the use of a 4" diameter ram when using the JD "D" ...I NEVER did check the Pump PSI:
The 3" diam Ram was not large enough, given the pump out put (psi) when using the JD "D"
Today my Case 830 with hydraulics <2000 psi require the usage of the 4" diam. Ram (on the above disc) once the oil is up to operating Temperature:
Keep it simple:
Force= Psi X Piston / Area
Psi @ 650 .....Ram Diam @ 4".........(2X2) X 3.142= 12.568 X 650 psi =8169.2 / 2000 = 4+ Tons...does your disc weigh 4 Tons??
Psi @ 650......Ram Diam @ 3".........(1.5 X 1.5) X 3.142 = 7.069 X 650 psi = 4595.1 / 2000 = 2.29 Tons...does you disc weigh 2 1/4 Tons???
Psi@ 600......Ram Diam @ 4"........(2X2) X 3.142 = 12.568 x 600 psi =7540.8 / 2000 = 3.77 Tons...does your disc weigh 3 7/4 Tons ?????
Hope the Math is correct...it's late out here in Alberta.....
Bob.....
Mike M
PostPosted: Fri Sep 20, 2019 3:57 am    Post subject: Re: Hydraulic Pressure Reply to specific post Reply with quote
Oh, I thought you had one of each of the listed tractors ?
Joel Sanderson
PostPosted: Fri Sep 20, 2019 3:15 pm    Post subject: Re: Hydraulic Pressure Reply to specific post Reply with quote
You're teasing, I'm thinkin. :) Between my dad and myself, our two-bangers are an 80, 730, A and now this D (which makes him grumble).
Joel Sanderson
PostPosted: Sat Sep 21, 2019 3:01 am    Post subject: Re: Hydraulic Pressure Reply to specific post Reply with quote
That's really helpful, Bob. Thank you very much. I'll check the seeder's book to see what it weighs and what size ram the D'll need.
It sounds like the D pulled the disc that the R blew smoke and fire out its top to pull. Did I read that right? Are you saying they're about the same drawbar horsepower? I've never been around an R, but my grandfather's best friend had one, and I've heard a lot of stories about how tough it was--back when it was the biggest tractor in the area. It was the inspiration for my dad to get his 80.
I sure like your picture of the pressure gauge. I need to get one of those.
