Ford 4 cylinder engine ID and firing order
poconojoe57
PostPosted: Mon Sep 23, 2019 9:32 am    Post subject: Ford 4 cylinder engine ID and firing order Reply to specific post Reply with quote
Hi all, newbie here... I've been lurking around looking for answers, but thought maybe I should just ask.
We don't have a tractor, but it's basically a tractor engine. It's a Ford Industrial 4 cylinder in a wood chipper. Stamped on the engine is CONN 6015J. I have no idea which engine this is. 134, 172, 192 cid....
I'm a bit confused with what I've read online as to the location of #1 cylinder. Is it at the front nearest the cooling fan or at the rear nearest the transmission? From reading here I see that the firing order should be 1,2,4,3.
I believe the engine is currently seized, but I'm hoping it's just from sitting too long. We poured penetrating oil into each cylinder for it to soak a bit. Hopefully we can turn the crankshaft nut by hand in a few days to break it loose.
Thanks for viewing my post,
Joe
Jim L WA
PostPosted: Mon Sep 23, 2019 12:47 pm    Post subject: Re: Ford 4 cylinder engine ID and firing order Reply to specific post Reply with quote
I can't help with the identity, but you have the firing order correct and number one is at the front end.
poconojoe57
PostPosted: Mon Sep 23, 2019 1:23 pm    Post subject: Re: Ford 4 cylinder engine ID and firing order Reply to specific post Reply with quote
Thanks for the info. I really appreciate the response.
Glad I came here for expert info. Diagrams all over the internet looked as if the #1 cylinder was at the rear end of the block.
Sean in PA
PostPosted: Mon Sep 23, 2019 1:48 pm    Post subject: Re: Ford 4 cylinder engine ID and firing order Reply to specific post Reply with quote
C0NN6015J is a 172 ci engine. As Jim has said, the number 1 cylinder is at the front where the water pump is located and the firing order is 1,2,4,3.
poconojoe57
PostPosted: Tue Sep 24, 2019 6:06 am    Post subject: Re: Ford 4 cylinder engine ID and firing order Reply to specific post Reply with quote
Thanks for your response!
We have another engine that has "CONN 6015G" stamped on it. Is this also a 172 cid?
Sean in PA
PostPosted: Tue Sep 24, 2019 6:55 am    Post subject: Re: Ford 4 cylinder engine ID and firing order Reply to specific post Reply with quote
C0NN6015G is 134 ci.
