Ford 860 Head Gasket Replacement
TGBTG7701
PostPosted: Sun Sep 29, 2019 2:15 pm    Post subject: Ford 860 Head Gasket Replacement Reply to specific post Reply with quote
I am replacing my head gasket on my 172 gas engine. When I pulled the head I noticed some pitting around the sleeve and block on #2 and #3, #2 being the worse and coming extremely close to the sealing area on the head gasket. Has anyone seen this before? Do you think it will cause an issue with sealing? Do I need to use sealant on the head gasket (new style- not steel) to insure it seals ( like aviation sealer or copper coat)? I am not set up to pull the engine, and rebuild it, I know a machine shop could deck the block and get the pitting out.
The head is going to the machine shop, it will be flat and ready to go, but I am worried about the block. What do you think?
Royse
PostPosted: Sun Sep 29, 2019 3:19 pm    Post subject: Re: Ford 860 Head Gasket Replacement Reply to specific post Reply with quote
Hard to say without knowing how bad it is. Can you post a picture?
I've had quite a few with some pitting that sealed fine.
I normally use copper coat unless the gasket kit says not to.
el6147
PostPosted: Sun Sep 29, 2019 3:59 pm    Post subject: Re: Ford 860 Head Gasket Replacement Reply to specific post Reply with quote
you can deck the block your self without removing the engine, sleeves or pistons and it
should be done ,
I helped out another YT poster do the procedure just recently , if you email me I can
explain the how's and why's with photos.
Threewilsons
PostPosted: Sun Sep 29, 2019 5:15 pm    Post subject: Re: Ford 860 Head Gasket Replacement Reply to specific post Reply with quote
If you have a good straight edge you can see if there is a low area between 2&3. Blowing a head gasket between 2&3 is not uncommon on gas 172 engines. If you see a gap below the straight edge, try to measure it with a gauge. I would do something if it exceeded 2 thousandths.
I very recently repaired (had the block decked) my gas 172 for blowing gasket between 2&3. Measuring across the block, it was between 3 and 4 thousandths low.
I don t know why you couldn t use the copper. Also I ve heard of trying this up using a flat file but I haven t done that. You might consider torquing head bolts to diesel spec - if your 172 has 1/2 inch headbolts. Good luck, -Joel
TGBTG7701
PostPosted: Sun Sep 29, 2019 6:07 pm    Post subject: Re: Ford 860 Head Gasket Replacement Reply to specific post Reply with quote
Thank you for the replies, I appreciate the help. I am going place the new gasket on the block and trace around the sealing area, see how close it is. I had a really nice shop to work in before hurricane Michael, but lost it along with all my tools. It makes it just about impossible to pull the motor. I am trying to get my tractor going so I can use it to clear and grade my property I purchase after the hurricane.
showcrop
PostPosted: Mon Sep 30, 2019 3:17 am    Post subject: Re: Ford 860 Head Gasket Replacement Reply to specific post Reply with quote
TGBTG7701 wrote:
(quoted from post at 19:07:29 09/29/19)
It sounds like you plan to measure under the gasket. This won't work. Use a steel ruler as from a carpenter's combination square, sitting on edge. Use feelr gauges under it.
