reversing sediment bowl ?
labjack
PostPosted: Wed Oct 02, 2019 8:11 pm    Post subject: reversing sediment bowl ? Reply to specific post Reply with quote
I have a 63 4000 gasser. Is there any effect/harm in reversing the sediment bowl so that the gas line fitting is on the outside instead of the inside. I did this because it was easier to reroute the fuel line that way. Seems like I've read somewhere that it could restrict the fuel flow somewhat. True, or no?
Thanks, Mark
MarkB_MI
PostPosted: Thu Oct 03, 2019 1:45 am    Post subject: Re: reversing sediment bowl ? Reply to specific post Reply with quote
So you've turned the bowl assembly 180 degrees so the fuel line points up and outboard rather than up and inboard? I don't see how that could affect fuel flow.
JMOR
PostPosted: Thu Oct 03, 2019 2:42 am    Post subject: Re: reversing sediment bowl ? Reply to specific post Reply with quote
labjack wrote:
(quoted from post at 00:11:13 10/03/19) I have a 63 4000 gasser. Is there any effect/harm in reversing the sediment bowl so that the gas line fitting is on the outside instead of the inside. I did this because it was easier to reroute the fuel line that way. Seems like I've read somewhere that it could restrict the fuel flow somewhat. True, or no?
Thanks, Mark
Looks like there may be a problem. Notice the non-symmetry of the part that hollow bolt passes thru relative to the center-line of fuel line as well as path in casting going down to bowl? This may throw off alignment between hole in hollow bolt and the passages. Look into the bottom of sediment bowl casting (as in picture here) and see if hollow bolt hole alignment is correct or compromised. Check fuel line inlet for same.
oldseabee
PostPosted: Thu Oct 03, 2019 7:49 am    Post subject: Re: reversing sediment bowl ? Reply to specific post Reply with quote
labjack wrote:
(quoted from post at 21:11:13 10/02/19) I have a 63 4000 gasser. Is there any effect/harm in reversing the sediment bowl so that the gas line fitting is on the outside instead of the inside. I did this because it was easier to reroute the fuel line that way. Seems like I've read somewhere that it could restrict the fuel flow somewhat. True, or no?
Thanks, Mark
Didn't make any difference on mine with the temporary tank on it.
Destroked 450
PostPosted: Thu Oct 03, 2019 8:38 am    Post subject: Re: reversing sediment bowl ? Reply to specific post Reply with quote
Fuel line close to the engine helps to keep it from getting snagged by limbs or brush when working in rough areas, other wise it doesn't matter.
labjack
PostPosted: Thu Oct 03, 2019 10:39 am    Post subject: Re: reversing sediment bowl ? Reply to specific post Reply with quote
My routing is like your second pic only with the bowl reversed. Sometimes it seems like it may be starving for fuel a bit(under load). I should be able to put it back on the original side to see if it makes any difference. I also suspect a fitting I have between the fuel shutoff and the fuel line. It has a narrower opening than the fuel line. Not sure if it can be drilled out or not. Had to use that fitting when I switched shutoff valves from lever to shutoff type.
JMOR
PostPosted: Thu Oct 03, 2019 1:31 pm    Post subject: Re: reversing sediment bowl ? Reply to specific post Reply with quote
labjack wrote:
(quoted from post at 14:39:54 10/03/19)
No need to worry about adequate flow. Remove drain plug from bottom of carb and let flow until fill a pint jar....if fill in less than 2 minutes, that will be more flow that engine can burn.
labjack
PostPosted: Thu Oct 03, 2019 1:46 pm    Post subject: Re: reversing sediment bowl ? Reply to specific post Reply with quote
Good point, thanks.
George by Geneva, NY
PostPosted: Sat Oct 12, 2019 3:58 pm    Post subject: Re: reversing sediment bowl ? Reply to specific post Reply with quote
OOOOHHH, yes it does make a difference. Found out when tractor died in traffic from fuel starvation. This is from a few years back, but as I remember, the hollow where the bolt goes in is smaller on the end where the bolt originally goes in. I think I took a large rattail file and enlarged the smaller end, never had the problem again. Play with the parts and you should see the issue. Possible that some aftermarket filters are large bore all the way thru, don't know. Orig did have the 2 diameters.
labjack
PostPosted: Sun Oct 13, 2019 6:38 pm    Post subject: Re: reversing sediment bowl ? Reply to specific post Reply with quote
CVPost-George by Geneva, wrote:
(quoted from post at 16:58:23 10/12/19) OOOOHHH, yes it does make a difference. Found out when tractor died in traffic from fuel starvation. This is from a few years back, but as I remember, the hollow where the bolt goes in is smaller on the end where the bolt originally goes in. I think I took a large rattail file and enlarged the smaller end, never had the problem again. Play with the parts and you should see the issue. Possible that some aftermarket filters are large bore all the way thru, don't know. Orig did have the 2 diameters.
Interesting.... I'll have to check that out.
