Sherman combo troubles.
NBerg
PostPosted: Wed Oct 09, 2019 8:58 am    Post subject: Sherman combo troubles. Reply to specific post Reply with quote
So, I finally gave in and created my account to ask this question. I have a 1950 ford 8N that was rebuilt maybe 10 years ago and was in need of some TLC when I purchased it. A friend of mine rebuilt an early Sherman combo (no neutral detent) to install into my 8n, which was other wise, stock. We are currently on our 4th try of install the Sherman. When we get everything together, start the tractor and put the Sherman in any gear (up, down or standard, doesnt matter) and let off the clutch the tractor will whine and vibrate. The pitch changes tone with the gears, high for up, low for down and some where between the two for standard. My friend and I split the tractor again a few days ago and it looks like the output shaft gear of the Sherman is meshing very hard against the tractor's transmission gear. Could this be a symptom of too much preload? We believe we have the correct output shaft for the Sherman.
Kirk-NJ
PostPosted: Wed Oct 09, 2019 2:03 pm    Post subject: Re: Sherman combo troubles. Reply to specific post Reply with quote
Did you yes shims to get the preload right?
NBerg
PostPosted: Wed Oct 09, 2019 2:20 pm    Post subject: Re: Sherman combo troubles. Reply to specific post Reply with quote
I just now measured all the shims I used previously. They add up to .03. I just received some more shims and will start out with .05 like the shop manual says.
NBerg
PostPosted: Thu Oct 10, 2019 5:23 am    Post subject: Re: Sherman combo troubles. Reply to specific post Reply with quote
After comparing the output shaft of the Sherman to the stock shaft, the Sherman output gear is slightly smaller in diameter than the stock shaft. However, the inner tapered race of the output gear of the Sherman is wider in diameter than the stock's race. To me that makes it seem like I have been putting too many shims in, pulling it away from the bearing and into the larger tractor gear. I assume the bearing exists to keep the output gear the proper distance from the tractor's gear. With .55 thousands worth of shims and a 1/32 gasket, it still would whine. Also, with the Sherman in gear, turning it over slowly my hand, I could feel very tooth mesh with the tractor like the shaft had its own detents. All this seems like the output gear is pressed too hard against the tractors gesr. Could it be the Sherman is new and the tractor gear is old? The bearing is old and not holding up the sherman? The mounting plate is not machined properly?
NBerg
PostPosted: Thu Oct 10, 2019 6:53 am    Post subject: Re: Sherman combo troubles. Reply to specific post Reply with quote
.055 worth of shims*, sorry.
Kirk-NJ
PostPosted: Fri Oct 11, 2019 1:05 am    Post subject: Re: Sherman combo troubles. Reply to specific post Reply with quote
The bearing in the main trans should fit snugly into the race on the sherman output shaft. Is your bearing worn or has the race been machined causing slop in on the main shaft?
When sherman is installed you should be able to turn the input shaft with your thumb and two index fingers. Manual should give you pounds for preload. Gears in main trans
should mesh and there should be no up/down movement on main shaft in tranny. Although the sherman gets it's lube for a slinger in the main trans you still will need to put oil
in the sherman when installing.
NBerg
PostPosted: Fri Oct 11, 2019 1:56 am    Post subject: Re: Sherman combo troubles. Reply to specific post Reply with quote
With no shaft in, the bearing cage has a lot of play, however it does not click or feel gritty when I press it to the rear of the tractor and rotate it.
