clutch in a 7700
bobwhitecar
PostPosted: Sat Oct 12, 2019 9:21 am    Post subject: clutch in a 7700 Reply to specific post Reply with quote
I am replacing the clutch in a 7700 ford, my question is on the flywheel there is 2 doll pins on the flywheel where the pressure plate would bolt up, and I have 2 shims that were on those doll pins that seemed to shim the pressure plate away from the flywheel, but no shims where there were no doll pins?
shaun wallace
PostPosted: Sat Oct 12, 2019 10:05 am    Post subject: Re: clutch in a 7700 Reply to specific post Reply with quote
Had shims when new, needs them. Some used flat washers instead of the long shims.
Bern
PostPosted: Sat Oct 12, 2019 11:40 am    Post subject: Re: clutch in a 7700 Reply to specific post Reply with quote
Should be 4 shims measuring .090 - .100" thick as shown in location #7 at the link below. Using only 2 shims
could warp the pressure plate I would think.
Shims
Bern
PostPosted: Sat Oct 12, 2019 11:41 am    Post subject: Re: clutch in a 7700 Reply to specific post Reply with quote
The factory never used flat washers, although they would certainly work if they were the correct thickness.
bobwhitecar
PostPosted: Sat Oct 12, 2019 11:44 am    Post subject: Re: clutch in a 7700 Reply to specific post Reply with quote
I thought it odd that they used any kind of spacer,
