correct operating temp for a 4000 gas 4cyl?
Goto page 1, 2  Next
bob kuczynski
PostPosted: Mon Oct 14, 2019 12:59 pm    Post subject: correct operating temp for a 4000 gas 4cyl? Reply to specific post Reply with quote
i had a new thermostat put in after realizing i never had one at all.
tractor runs at 200-230 during peak usage. good? bad? no signs of over boiling. all seems secure.
its just my gas tank is still making my gas bubble. seems pretty hot to me up on top.
ideas?
JMOR
PostPosted: Mon Oct 14, 2019 1:06 pm    Post subject: Re: correct operating temp for a 4000 gas 4cyl? Reply to specific post Reply with quote
bob kuczynski wrote:
(quoted from post at 16:59:51 10/14/19) i had a new thermostat put in after realizing i never had one at all.
ideas?
what degree is thermostat? what temp was it running before thermostat installed?
Larry NCKS
PostPosted: Mon Oct 14, 2019 1:51 pm    Post subject: Re: correct operating temp for a 4000 gas 4cyl? Reply to specific post Reply with quote
Too hot! Maybe a timing issue. Maybe a cooling system issue of some kind.
Bern
PostPosted: Mon Oct 14, 2019 2:09 pm    Post subject: Re: correct operating temp for a 4000 gas 4cyl? Reply to specific post Reply with quote
200 wouldn't bother me, but 230 sure would.
bob kuczynski
PostPosted: Mon Oct 14, 2019 3:10 pm    Post subject: Re: correct operating temp for a 4000 gas 4cyl? Reply to specific post Reply with quote
its a 173.
same temp with or without.
Dean
PostPosted: Mon Oct 14, 2019 3:31 pm    Post subject: Re: correct operating temp for a 4000 gas 4cyl? Reply to specific post Reply with quote
First step is to verify that the temperature gauge is accurate.
Dean
bob kuczynski
PostPosted: Mon Oct 14, 2019 3:51 pm    Post subject: Re: correct operating temp for a 4000 gas 4cyl? Reply to specific post Reply with quote
aha!
jut went out and looked at the gauge cold. its stuck on 190.
JMOR
PostPosted: Mon Oct 14, 2019 5:38 pm    Post subject: Re: correct operating temp for a 4000 gas 4cyl? Reply to specific post Reply with quote
(quoted from post at 19:51:55 10/14/19) aha!
exactly why I asked the question.
bob kuczynski
PostPosted: Mon Oct 14, 2019 6:12 pm    Post subject: Re: correct operating temp for a 4000 gas 4cyl? Reply to specific post Reply with quote
ok, so next would be a fix for gas bubbling in the tank. i dont see a heat shield under the tank. is it missing?
Dean
PostPosted: Wed Oct 16, 2019 4:32 am    Post subject: Re: correct operating temp for a 4000 gas 4cyl? Reply to specific post Reply with quote
Yes. There should be a heat shield between the muffler and fuel tank. You do need it.
Verify correct ignition timing and proper operation of the mechanical advance mechanism.
Avoid gasoline with ethanol if at all possible.
Dean
bob kuczynski
PostPosted: Wed Oct 16, 2019 6:03 am    Post subject: Re: correct operating temp for a 4000 gas 4cyl? Reply to specific post Reply with quote
timing is perfect.
87 oct ethenol is all i got in this area. im using gas additive STABIL since tractor sits for some time off season.
bob kuczynski
PostPosted: Wed Oct 16, 2019 6:09 am    Post subject: Re: correct operating temp for a 4000 gas 4cyl? Reply to specific post Reply with quote
there is a shield over the muffler exhuast pipe. its the tank itself exposed to the valve cover area that im suspect of.
bob kuczynski
PostPosted: Fri Oct 18, 2019 6:24 am    Post subject: Re: correct operating temp for a 4000 gas 4cyl? Reply to specific post Reply with quote
bob kuczynski
PostPosted: Fri Oct 18, 2019 6:25 am    Post subject: Re: correct operating temp for a 4000 gas 4cyl? Reply to specific post Reply with quote
any addictive you suggest to mix in ethanol gas to make it run cooler?
RayJohnson
PostPosted: Fri Oct 18, 2019 11:34 am    Post subject: Re: correct operating temp for a 4000 gas 4cyl? Reply to specific post Reply with quote
(quoted from post at 07:09:05 10/16/19) there is a shield over the muffler exhuast pipe. its the tank itself exposed to the valve cover area that im suspect of.
It's hard for me to believe the heat from the motor is boiling the gas in your tank... (if that's what you're suggesting)
Goto page 1, 2  Next
Page 1 of 2
