correct operating temp for a 4000 gas 4cyl?
Goto page Previous  1, 2
Keith Williams
PostPosted: Mon Oct 21, 2019 11:41 am    Post subject: Re: correct operating temp for a 4000 gas 4cyl? Reply to specific post Reply with quote
Ray,
Boiling the gas is known to happen in these.
I can remember it happening from the time we first got our 4000 in April of 64.
Plowing for winter wheat in August after we cut the oats was when I remember it the most back then.
I have it happen now when I rotary cut with a 6 foot Woods mower.
I have even seen the bubbles coming down the fuel line into the sediment bowl.
BTW, the motor never stops because of this.
Keith
bob kuczynski
PostPosted: Fri Oct 25, 2019 2:32 pm    Post subject: Re: correct operating temp for a 4000 gas 4cyl? Reply to specific post Reply with quote
i wonder if putting an insulation board over the heat shield will help? you know the kind, it sorta looks like styrofoam with aluminium film over it.
hmmm?
RayJohnson
PostPosted: Fri Oct 25, 2019 4:04 pm    Post subject: Re: correct operating temp for a 4000 gas 4cyl? Reply to specific post Reply with quote
CVPost-Keith Williams wrote:
(quoted from post at 12:41:51 10/21/19) Ray,
Keith
Wow Keith, I would have never thought.
bob kuczynski
PostPosted: Sat Oct 26, 2019 7:52 am    Post subject: Re: correct operating temp for a 4000 gas 4cyl? Reply to specific post Reply with quote
anyone else?
Keith Williams
PostPosted: Mon Oct 28, 2019 12:08 pm    Post subject: Re: correct operating temp for a 4000 gas 4cyl? Reply to specific post Reply with quote
Bob,
You could try enriching the fuel mixture.
Ethanol gas (E10) will make the engine run a little leaner.
Make sure you have COMPLETELY cleaned the radiator fins. I like to use compressed air for this.
I would not put a foam panel under the tank. The gas is boiling because it is hotter than ~170 degrees. The foam products (I believe) will melt and possibly burn at those temps.
HTH
Keith
Page 2 of 2
