7600 fuel tank bracket
dbeam
PostPosted: Tue Oct 15, 2019 6:12 pm    Post subject: 7600 fuel tank bracket Reply to specific post Reply with quote
I have a 7600 ford that came with out a cab (now has an after market cab) and the sn is C491817. The front bracket that supports the fuel tank is broken and didn't know if anyone knew of where to get one. I think this may be the part number E5NN16B814AA but not entirely sure as it list 4 or 5 numbers https://www.messicks.com/nh/58362 #21. I am looking for something cheaper then Messicks, will have welded if I can't find another option but would rather replace then deal with welding. Thanks.
showcrop
PostPosted: Wed Oct 16, 2019 3:11 am    Post subject: Re: 7600 fuel tank bracket Reply to specific post Reply with quote
You are not likely to do better on price than Messicks. You will need to remove the bracket to replace it, and once you have gotten the bracket out getting it welded should be no problem.
Bern
PostPosted: Wed Oct 16, 2019 3:44 am    Post subject: Re: 7600 fuel tank bracket Reply to specific post Reply with quote
I agree with showcrop. You have to take it out anyway, just weld it. It would be very quick and easy to do.
Besides, the odds that NH still sells that part is well below 50/50. Just because the website lists a price
does not mean it's available.
dbeam
PostPosted: Wed Oct 16, 2019 4:15 am    Post subject: Re: 7600 fuel tank bracket Reply to specific post Reply with quote
CVPost-Bern wrote:
(quoted from post at 04:44:03 10/16/19) I agree with showcrop. You have to take it out anyway, just weld it. It would be very quick and easy to do.
Thanks for the input, makes my decision going forward much easier. I already have it down, I'll get someone better at welding then me to do it. Its really hard to know that its broken with out really looking for it, only reason I caught it was because I'm in process of changing the steering gear.
dbeam
PostPosted: Tue Oct 29, 2019 5:54 pm    Post subject: Re: 7600 fuel tank bracket Reply to specific post Reply with quote
Had a good welder weld it back together, looks stronger then ever. Thanks all for the input.
showcrop
PostPosted: Wed Oct 30, 2019 2:53 am    Post subject: Re: 7600 fuel tank bracket Reply to specific post Reply with quote
dbeam wrote:
(quoted from post at 18:54:59 10/29/19) Had a good welder weld it back together, looks stronger then ever. Thanks all for the input.
Thanks for posting back
