Ford 641 knocking
jo.knight@fwcs.k12.in.us
PostPosted: Sun Oct 20, 2019 1:03 pm    Post subject: Ford 641 knocking Reply to specific post Reply with quote
I have a ford 641. I was grading the lane like I do often. The
tractor started to knock so hard the entire trActor shook and
died. I towed it back to the shed. It will turn over but it knocks
so bad. It sounds like the knock is under the hood, but it
shook so hard it even shook the seat. Any ideas what is
going on with it?
CTPhil
PostPosted: Sun Oct 20, 2019 1:38 pm    Post subject: Re: Ford 641 knocking Reply to specific post Reply with quote
Last time I had that it was a spun rod bearing. I don't know if that's your issue but your description is not of something that's an easy fix.
PostPosted: Sun Oct 20, 2019 1:43 pm    Post subject: Re: Ford 641 knocking Reply to specific post Reply with quote
I?m sure it is an expensive fix whatever it is. Thanks for your
response.
docmirror
PostPosted: Sun Oct 20, 2019 1:45 pm    Post subject: Re: Ford 641 knocking Reply to specific post Reply with quote
If it shakes the tractor, it's either a broken crankshaft, or at the flywheel.
PostPosted: Sun Oct 20, 2019 1:49 pm    Post subject: Re: Ford 641 knocking Reply to specific post Reply with quote
Thanks so Much.
CTPhil
PostPosted: Mon Oct 21, 2019 4:21 am    Post subject: Re: Ford 641 knocking Reply to specific post Reply with quote
Unfortunately the only thing to do is start taking it apart and see what's broken :(
showcrop
PostPosted: Mon Oct 21, 2019 4:50 am    Post subject: Re: Ford 641 knocking Reply to specific post Reply with quote
I would be on the hunt for a used motor, either a 134 or a 172. If you share your location you can get suggestions on where to look.
PostPosted: Mon Oct 21, 2019 5:50 am    Post subject: Re: Ford 641 knocking Reply to specific post Reply with quote
Fort Wayne, IN
bobwhitecar
PostPosted: Mon Oct 21, 2019 1:00 pm    Post subject: Re: Ford 641 knocking Reply to specific post Reply with quote
drop the oil pan and look at the rods
bobwhitecar
PostPosted: Mon Oct 21, 2019 1:03 pm    Post subject: Re: Ford 641 knocking Reply to specific post Reply with quote
I am not that far away if you need it worked on
