Ford 5000
Gerard 1702
PostPosted: Wed Oct 23, 2019 11:59 am    Post subject: Ford 5000 Reply to specific post Reply with quote
Hi all I have 1968 Ford 5000 that needs an engine. I have been offered an engine out of a 7000. Would this be a straight replacement would I need to change anything else as there s gonna be a jump in horsepower now running all through the tractor?
shaun wallace
PostPosted: Wed Oct 23, 2019 12:57 pm    Post subject: Re: Ford 5000 Reply to specific post Reply with quote
Direct bolt in. Tach will be driven off inj pump instead of gen if even works.
Bern
PostPosted: Wed Oct 23, 2019 1:34 pm    Post subject: Re: Ford 5000 Reply to specific post Reply with quote
A 7000 has a stronger tranny and larger cooling package. Keep that in mind if you make the swap and all of a
sudden start liking the extra power.
Gerard 1702
PostPosted: Thu Oct 24, 2019 2:48 am    Post subject: Re: Ford 5000 Reply to specific post Reply with quote
Ok thanks guys. Would the extra power only be one an issue if the tractor was been worked hard on a very frequent basis ?
Sean in PA
PostPosted: Thu Oct 24, 2019 3:36 am    Post subject: Re: Ford 5000 Reply to specific post Reply with quote
Gerard 1702 wrote:
(quoted from post at 06:48:01 10/24/19) Ok thanks guys. Would the extra power only be one an issue if the tractor was been worked hard on a very frequent basis ?
History of the transmission would be a factor, if it was already worn some from being run hard in the past, then running it hard with the more powerful engine may cause issues earlier than if it had an original hp engine. But even if it was never worked hard with the original engine, over working it with the 7000 engine could cause issues on its own.
Ultradog MN
PostPosted: Thu Oct 24, 2019 4:22 am    Post subject: Re: Ford 5000 Reply to specific post Reply with quote
I would say Bern put it best.
It's similar to putting a 172 ci engine
from an 800 in place of the 134 in a
600.
They're a direct swap and the 600 would
do a lot of useful work, for many years,
as long as you don't lay into it hard
all the time.
In the 800/600 case you'd blow the rear
end, not the transmission but kaput is
kaput after all.
Bern
PostPosted: Thu Oct 24, 2019 4:30 am    Post subject: Re: Ford 5000 Reply to specific post Reply with quote
With regards to the tranny, yes. With regards to the cooling system, it won't take long for the stock 5000
cooling system to overheat if the engine is run at full load. I'm talking minutes, not hours.
At a minimum I'd put a larger fan in it.
JK-NY
PostPosted: Thu Oct 24, 2019 4:42 am    Post subject: Re: Ford 5000 Reply to specific post Reply with quote
As mentioned I would be concerned with cooling capacity. The
engine should pretty much be a bolt in fit. Not sure if you can
use the 7000 radiator in the 5000 too but I would be looking at
options to upgrade the cooling system. If you have a good
radiator shop they may be able to help you, although good
radiator shops are getting rarer than hens teeth.
Gerard 1702
PostPosted: Thu Oct 24, 2019 6:20 am    Post subject: Re: Ford 5000 Reply to specific post Reply with quote
Thanks everyone for the useful info
Destroked 450
PostPosted: Thu Oct 24, 2019 6:37 am    Post subject: Re: Ford 5000 Reply to specific post Reply with quote
The 7000 engine is a direct bolt on but as others have said it's best to upgrade to a 7000 radiator which will fit.
The issue I see is the air cleaner system, 5000 has a oil bath air cleaner and 7000 uses a dry element (paper) air filter, all of the piping is different in order to connect the air cleaner system to the 7000's turbocharger, even the front radiator shell is different to allow for the different air cleaner.
To use the 5000's oil bath air cleaner you'll have to fab the piping.
Gerard 1702
PostPosted: Thu Oct 24, 2019 6:53 am    Post subject: Re: Ford 5000 Reply to specific post Reply with quote
Destroked 450 wrote:
(quoted from post at 07:37:15 10/24/19)
Great piece of information very informative sounds difficult but not impossible?
SkipperII
PostPosted: Sat Oct 26, 2019 6:23 pm    Post subject: Re: Ford 5000 Reply to specific post Reply with quote
This past spring, I located a 7000 air cleaner assembly, and a new grilles shell. Using exhaust elbows and tubing, I switched a buddies'
5000 over to a dry system, so it can be done, with a little adapting. He hated the oil bath, and had bugged me for three years.
