Ford 861 Hydraulic valve operation?
TSwalla
PostPosted: Fri Nov 01, 2019 1:17 pm    Post subject: Ford 861 Hydraulic valve operation? Reply to specific post Reply with quote
I recently purchased a Ford 861 that has a hydraulic control valve on it. When I push the lever in one direction it pressurizes one of the hoses, when I push it in the other direction it doesn't do anything. Can anyone tell me what the knob (arrow pointing to it) is supposed to do?
[/img]
Royse
PostPosted: Fri Nov 01, 2019 4:40 pm    Post subject: Re: Ford 861 Hydraulic valve operation? Reply to specific post Reply with quote
I'm not familiar with that particular valve, but on other valves, a
screw in that location changes it from single acting to dual acting.
You might try turning it all the way in or out to see if it changes.
Welcome to the forums!
TSwalla
PostPosted: Fri Nov 01, 2019 7:32 pm    Post subject: Re: Ford 861 Hydraulic valve operation? Reply to specific post Reply with quote
Thanks, I'll give that a try.
Here's another view of that valve. I believe it's an OEM valve.
Ultradog MN
PostPosted: Sat Nov 02, 2019 9:49 am    Post subject: Re: Ford 861 Hydraulic valve operation? Reply to specific post Reply with quote
That valve is newer than your tractor.
My 66 model had that style from the
factory.
Not that that matters. The same valve
will fit Fords from 1955 till at least
1981.
TSwalla
PostPosted: Sat Nov 02, 2019 11:46 am    Post subject: Re: Ford 861 Hydraulic valve operation? Reply to specific post Reply with quote
Can you tell me if the adjustment know should be turned all the way in or out to change from single to dual activation?
TSwalla
PostPosted: Sat Nov 02, 2019 4:20 pm    Post subject: Re: Ford 861 Hydraulic valve operation? Reply to specific post Reply with quote
I tried turning the know in fully and backing it out to the point that it would not leak, it made no difference, still acts like a single action valve.
Ultradog MN
PostPosted: Sat Nov 02, 2019 9:54 pm    Post subject: Re: Ford 861 Hydraulic valve operation? Reply to specific post Reply with quote
I can't help on which way to turn the
knob. My tractor is still in a hundred
pieces and I've not used the valve yet.
Sean in PA
PostPosted: Sun Nov 03, 2019 5:36 am    Post subject: Re: Ford 861 Hydraulic valve operation? Reply to specific post Reply with quote
I'm not familiar with that particular valve either, but in your first picture I see a small screw near the large black knob with a few threads exposed. That might be the screw that switches it from single acting to double acting. Try screwing that all of the way in to see if it switches to double acting. The large knob might be a flow control valve that controls how fast the fluid flows.
TSwalla
PostPosted: Sun Nov 03, 2019 6:25 am    Post subject: Re: Ford 861 Hydraulic valve operation? Reply to specific post Reply with quote
Sean in PA I'll give that a try, thanks for the suggestion.
Destroked 450
PostPosted: Sun Nov 03, 2019 7:34 am    Post subject: Re: Ford 861 Hydraulic valve operation? Reply to specific post Reply with quote
That knob is the float control valve, it must be turned completely in for double action to work
