Ford 5610
TJ Owner
PostPosted: Mon Nov 04, 2019 4:43 am    Post subject: Ford 5610 Reply to specific post Reply with quote
Just purchased a Ford 5610 with cab.
The 3PH is like grandpa on viagara, they are up, but won't go down at all.
There was no oil in the rear end when I first got the tractor, ended up putting a pail and a half of oil in before it finally registered on the dipstick.
Found a leak in the front where the hydraulic hoses go into the oil cooler, fixed that issue, however the 3PH is still stuck in the up position.
Possible air lock? If so, how to bleed it?
Bern
PostPosted: Mon Nov 04, 2019 10:24 am    Post subject: Re: Ford 5610 Reply to specific post Reply with quote
Hitch could be mechanically stuck, which happens sometimes if it's not used often. Try pushing down on the arms with something like a loader bucket.
TJ Owner
PostPosted: Mon Nov 04, 2019 10:33 am    Post subject: Re: Ford 5610 Reply to specific post Reply with quote
CVPost-Bern wrote:
(quoted from post at 11:24:19 11/04/19) Hitch could be mechanically stuck, which happens sometimes if it's not used often. Try pushing down on the arms with something like a loader bucket.
Tried that...also left 3 weights on it as well, no success...both 3PH and draft control levers are in the down position, and have tried with the diverter in and out...getting pressure at the hydraulic connectors at the back when you activate the lever for it...
Also, I am able to lift the 3PH arms up a few inches
TJ Owner
PostPosted: Mon Nov 04, 2019 10:34 am    Post subject: Re: Ford 5610 Reply to specific post Reply with quote
am able to lift the 3PH arms a few inches by hand
