Ford 2000 3cyl diesel valve clerance
Dirk Pitt
PostPosted: Sat Nov 09, 2019 5:48 am    Post subject: Ford 2000 3cyl diesel valve clerance Reply to specific post Reply with quote
Hi. I need values for valve clerances on Ford 2000 1965, 3cyl diesel. Been all over the internet and cant find it. Thanks.
sunbeam
PostPosted: Sat Nov 09, 2019 6:07 am    Post subject: Re: Ford 2000 3cyl diesel valve clerance Reply to specific post Reply with quote
15 intake 18 exhaust.warm
Tom in TN
PostPosted: Sat Nov 09, 2019 6:18 am    Post subject: Re: Ford 2000 3cyl diesel valve clerance Reply to specific post Reply with quote
Dirk,
According to my I&T Shop Manual, the cold adjustment is .017 for intake valves and .021 for exhaust valves. At operating temperature, intake valves are .015 and .018 for exhaust valves.
The manual has two pictures showing which valves can be adjusted at TDC on the compression stroke of the number one piston and which valves can be adjusted at TDC of the number one piston on the exhaust stroke. I'd send you a picture of the picture, but I have no idea how to do that.
No distinction is made in the manual for gasoline versus diesel engines.
Good luck,
Tom in TN
hurleyjd
PostPosted: Sat Nov 09, 2019 6:20 am    Post subject: Re: Ford 2000 3cyl diesel valve clerance Reply to specific post Reply with quote
Pretty gap there.
Valve clearance
Dirk Pitt
PostPosted: Sat Nov 09, 2019 6:21 am    Post subject: Re: Ford 2000 3cyl diesel valve clerance Reply to specific post Reply with quote
In millimeters please if you have the informatio because Im from Europe.
Tom in TN
PostPosted: Sat Nov 09, 2019 6:28 am    Post subject: Re: Ford 2000 3cyl diesel valve clerance Reply to specific post Reply with quote
Dirk,
My Ford 2000 Service Manual says that .017 inches is the equivalent of 43 mm, and that .019 inches is the equivalent of 48 mm. Knowing nothing about
metric measurements, I can't say if that sounds reasonable or not.
Tom in TN
hurleyjd
PostPosted: Sat Nov 09, 2019 6:53 am    Post subject: Re: Ford 2000 3cyl diesel valve clerance Reply to specific post Reply with quote
Inchs to MM
metric conversion
Destroked 450
PostPosted: Sat Nov 09, 2019 7:00 am    Post subject: Re: Ford 2000 3cyl diesel valve clerance Reply to specific post Reply with quote
Intake 0.36 - 0.41 mm
Exhaust 0.43 - 0.48 mm
I set mine to the max setting cold.
Tom in TN
PostPosted: Sat Nov 09, 2019 8:36 am    Post subject: Re: Ford 2000 3cyl diesel valve clerance Reply to specific post Reply with quote
Ah, Yes. I just looked at my manual again and saw that it should be .43 and .48 millimeters NOT just plain 43 and 48.
Sorry about that.
Tom in TN
Dirk Pitt
PostPosted: Sun Nov 10, 2019 7:58 am    Post subject: Re: Ford 2000 3cyl diesel valve clerance Reply to specific post Reply with quote
Thank you guys!
I have set it to .41mm intake and .48mm exhaust on cold engine.
Can this measures be applied on Ford 4000, 1966, 3 cyl diesel?
Destroked 450
PostPosted: Sun Nov 10, 2019 8:09 am    Post subject: Re: Ford 2000 3cyl diesel valve clerance Reply to specific post Reply with quote
Same setting for all Ford 3 cylinder, 65/later 4 cylinder and 6 cylinder engines
Dirk Pitt
PostPosted: Sun Nov 10, 2019 8:20 am    Post subject: Re: Ford 2000 3cyl diesel valve clerance Reply to specific post Reply with quote
Ok. Thanks for help!
