2610 - CAV Pump Leaking Fuel
Bouncer
PostPosted: Sat Nov 09, 2019 9:28 pm    Post subject: 2610 - CAV Pump Leaking Fuel Reply to specific post Reply with quote
The pump on my newly acquired 2610 has started leaking fuel fairly significantly. It is bad enough I have to shut the fuel off at the tank when not using the tractor or it will just keep dripping and dripping. It appears to be coming from either around the throttle shaft or the top itself. Everything was fine until I cleaned the tractor up real good and I guess I knocked all the crud off holding the leak back. The tractor starts easy and runs great even though the tach was broke when I got it and it shows 38xx hours. I figure it is a o-ring or seal, but I'm not for certain. After the tractor warms up it slows down to next to nothing and sometimes even stops. However with Winter coming on the leak is going to get worse with the temps. I live in Southern Indiana, does anyone within a couple hundred miles or so of me work on these pumps? I would be more than willing to haul the tractor to you and pay you to reseal the pump, even help out where I can if you would like. My health just does not allow for me to be able to do mechanical work like I used to and that is why I am selling off a lot of my antique tractor collection and getting a little more modern tractor to actually work with. Thanks
Bouncer
PostPosted: Sat Nov 09, 2019 9:31 pm    Post subject: Re: 2610 - CAV Pump Leaking Fuel Reply to specific post Reply with quote
I fat fingered the model number, it should say 2910 instead of 2610.
Welding man
PostPosted: Sun Nov 10, 2019 4:40 am    Post subject: Re: 2610 - CAV Pump Leaking Fuel Reply to specific post Reply with quote
Dieseltech can fix you up. He lives in Indiana. mhf35diesel@yahoo.com
RM-MN
PostPosted: Sun Nov 10, 2019 5:27 am    Post subject: Re: 2610 - CAV Pump Leaking Fuel Reply to specific post Reply with quote
I believe there are a pair of O-rings on that throttle shaft. Replace both of them. If the pump has a shut off shaft, do the same for it at the same time.
Dieseltech
PostPosted: Sun Nov 10, 2019 10:12 am    Post subject: Re: 2610 - CAV Pump Leaking Fuel Reply to specific post Reply with quote
I used to do top cover leak repairs, but no more. Too many times other leaks show up soon after, and the owner says, "but you just worked on it and it's leaking again". Best repair the complete pump and be done with it. Just my two cents, having been repairing pumps over forty years..
Bouncer
PostPosted: Sun Nov 10, 2019 4:58 pm    Post subject: Re: 2610 - CAV Pump Leaking Fuel Reply to specific post Reply with quote
Dieseltech, what part of the state are you in?
Dieseltech
PostPosted: Sun Nov 10, 2019 5:50 pm    Post subject: Re: 2610 - CAV Pump Leaking Fuel Reply to specific post Reply with quote
North central Indiana, about 100 miles straight north of Indianapolis. Feel free to call or text five seven four eight three five 3292 if you like.
Destroked 450
PostPosted: Sun Nov 10, 2019 6:11 pm    Post subject: Re: 2610 - CAV Pump Leaking Fuel Reply to specific post Reply with quote
Where in Southern Indiana do you live, I'm about 30 miles south of Corydon.
I won't work on the pump but I may be able to help take it off and reinstall it.
Bouncer
PostPosted: Mon Nov 11, 2019 8:53 pm    Post subject: Re: 2610 - CAV Pump Leaking Fuel Reply to specific post Reply with quote
I live in Corydon. You in the Brandenburg area? This tractor came from Falls of Rough.
Destroked 450
PostPosted: Tue Nov 12, 2019 7:20 am    Post subject: Re: 2610 - CAV Pump Leaking Fuel Reply to specific post Reply with quote
Yea I'm west of Brandenburg and about 30 miles from Corydon.
Do you have a shop or shed to put the tractor in, my shop is small and full, I have a 3930 engine I'm preping to go on a 555 Farmtrac tractor and have a F-800 waiting to have the frame stretched for a dump bed install, the list goes on.
I could come up and remove the pump so you can box it up and send to Dieseltech, when you get it back I'd come up and reinstall it.
Email is open in modern.
Bouncer
PostPosted: Tue Nov 12, 2019 6:31 pm    Post subject: Re: 2610 - CAV Pump Leaking Fuel Reply to specific post Reply with quote
Destroked 450 wrote:
(quoted from post at 08:20:14 11/12/19)
I just shot you an email.
Thanks!
