tc35a new holland injector pump
Dale2
PostPosted: Mon Nov 11, 2019 4:27 pm    Post subject: tc35a new holland injector pump Reply to specific post Reply with quote
Can anyone tell me what I need to do to the engine before I pull the injector pump off. Do I need to set it in a particular spot or not. Also is there anything internal to disconnect. My manual is not here yet.
Dale
Dieseltech
PostPosted: Mon Nov 11, 2019 5:47 pm    Post subject: Re: tc35a new holland injector pump Reply to specific post Reply with quote
Engine has a PFR type injection pump that uses internal engine cam, to timing needed to remove/replace. Just MAKE SURE the base shims under the pump are used as is, unless you want to bother with flow timing the pump.
