1963 Ford 2000 trouble starting
Goto page 1, 2  Next
Leever2000
PostPosted: Tue Nov 12, 2019 5:54 am    Post subject: 1963 Ford 2000 trouble starting Reply to specific post Reply with quote
Started and ran weekend before but now having problems starting. Has spark! New plugs, wires a year old at most and battery charged. Turns over just will not start.
showcrop
PostPosted: Tue Nov 12, 2019 6:05 am    Post subject: Re: 1963 Ford 2000 trouble starting Reply to specific post Reply with quote
When you look at the plugs after trying are they wet or dry?
Leever2000
PostPosted: Tue Nov 12, 2019 6:20 am    Post subject: Re: 1963 Ford 2000 trouble starting Reply to specific post Reply with quote
Wet,
Larry NCKS
PostPosted: Tue Nov 12, 2019 11:08 am    Post subject: Re: 1963 Ford 2000 trouble starting Reply to specific post Reply with quote
Leever2000 wrote:
(quoted from post at 09:20:45 11/12/19)
Wet,
getting fuel then. Got moisture in your distributor by chance? That my not stop spark, but may make it go places it shouldn't at the wrong times.
Larry NCKS
Wet,
showcrop
PostPosted: Tue Nov 12, 2019 2:18 pm    Post subject: Re: 1963 Ford 2000 trouble starting Reply to specific post Reply with quote
How well did it run last weekend? How long have you had it? Has the power been as expected when you worked it? What sort of work have you done with it? How many hours on the proof meter? Is the external appearance of and the number of hours on the proof meter consistent with the overall condition of the tractor?
MarkB_MI
PostPosted: Tue Nov 12, 2019 4:52 pm    Post subject: Re: 1963 Ford 2000 trouble starting Reply to specific post Reply with quote
In my experience, you can have "good" spark and still have trouble starting. Check the condition of your points. I finally gave up on replacement points and condensers due to the very poor quality of replacement parts. Over a year ago I installed a Pertronix conversion and haven't looked back.
Leever2000
PostPosted: Wed Nov 13, 2019 5:01 am    Post subject: Re: 1963 Ford 2000 trouble starting Reply to specific post Reply with quote
It ran well last weekend once got it started via pulling with truck and popping clutch. I've had the Ford for about 5 or 6 years and already have the Pertronix. The power been as expected when it is running? I use for plowing snow in the winter and during the other times it is used for gathering wood etc...? The external appearance and the number of hours on the proof meter are consistent with the overall condition of the tractor?
showcrop
PostPosted: Wed Nov 13, 2019 6:55 am    Post subject: Re: 1963 Ford 2000 trouble starting Reply to specific post Reply with quote
[quote="Leever2000"](quoted from post at 06:01:45 11/13/19) It ran well last weekend once got it started via pulling with truck and popping clutch. I've had the Ford for about 5 or 6 years and already have the Pertronix. The power been as expected when it is running? I use for plowing snow in the winter and during the other times it is used for gathering wood etc...? The external appearance and the number of hours on the proof meter are consistent with the overall condition of the tractor?[/quote
How many hours does your proofmeter read and does it appear to be the original?
Leever2000
PostPosted: Wed Nov 13, 2019 11:11 am    Post subject: Re: 1963 Ford 2000 trouble starting Reply to specific post Reply with quote
[quote="showcrop"](quoted from post at 10:55:37 11/13/19)
Approx 2970 hours will verify when get home and that sounds about right for a 55 yr old tractor. Average 50+ hours a year.
showcrop
PostPosted: Wed Nov 13, 2019 3:06 pm    Post subject: Re: 1963 Ford 2000 trouble starting Reply to specific post Reply with quote
[quote="Leever2000"](quoted from post at 12:11:43 11/13/19)
That is the second or third hour meter.
Leever2000
PostPosted: Wed Nov 13, 2019 3:41 pm    Post subject: Re: 1963 Ford 2000 trouble starting Reply to specific post Reply with quote
[quote="showcrop"](quoted from post at 19:06:24 11/13/19)
2623 hours
Leever2000
PostPosted: Thu Nov 14, 2019 7:11 am    Post subject: Re: 1963 Ford 2000 trouble starting Reply to specific post Reply with quote
After some thinking maybe it has been longer than last year that I did a tune-up. I went ahead and ordered plug wires, ditributor cap, rotor and 4 more plugs and then I will know that those items will not be the cause. Once I get them and install I will report the status and hopfully it will be good news.
MarkB_MI
PostPosted: Fri Nov 15, 2019 3:57 am    Post subject: Re: 1963 Ford 2000 trouble starting Reply to specific post Reply with quote
OK, when you said "new plugs" I assumed you meant you had replaced them AFTER the starting problem cropped up.
Here's something to try before your parts come in: Take out your spark plugs and burn off any carbon using a torch or a burner on your gas range. If you do this using an acetylene torch, use a slightly oxidizing flame and be very careful not to melt the electrodes. I'll bet your tractor will fire up with the cleaned plugs. Try starting initially with no choke and open throttle, as there's probably already plenty of fuel in the cylinders.
When you replace your plug wires, be sure to use resistance wires to protect your Pertronix unit.
Leever2000
PostPosted: Sat Nov 16, 2019 5:12 am    Post subject: Re: 1963 Ford 2000 trouble starting Reply to specific post Reply with quote
Yes I did replace the plugs but the plugs appear to be fouled already
Goto page 1, 2  Next
Page 1 of 2
