800 series ford
Elton Fancher
PostPosted: Sat Nov 23, 2019 8:23 pm    Post subject: 800 series ford Reply to specific post Reply with quote
Was working on 800 series tractor with loader. Put on head gasket, all that is great, runs good. Loader is Ford with reservoir in frame. Front pump. Problem is the speed of lift and lower. So fast it is scary and hard to control. Any way I could slow it down?
Bob
PostPosted: Sat Nov 23, 2019 10:42 pm    Post subject: Re: 800 series ford Reply to specific post Reply with quote
Most likely, you can learn to "feather" the lever to control the speed.
Off Road SHO
PostPosted: Sun Nov 24, 2019 3:04 am    Post subject: Re: 800 series ford Reply to specific post Reply with quote
CVPost-elton fancher wrote:
(quoted from post at 05:23:53 11/24/19) Was working on 800 series tractor with loader. Put on head gasket, all that is great, runs good. Loader is Ford with reservoir in frame. Front pump. Problem is the speed of lift and lower. So fast it is scary and hard to control. Any way I could slow it down?
Sure. Put on a longer lever. Or reduce the diameter of the hydraulic hoses.
Tom
RobCons
PostPosted: Sun Nov 24, 2019 5:05 am    Post subject: Re: 800 series ford Reply to specific post Reply with quote
Restricted orifice adapters are available that just screw inline. I put a set on a Massey Ferguson a couple years ago with good results. Some people dont like them. I got mine at TSC and drilled the hole out a little bigger.
Elton Fancher
PostPosted: Sun Nov 24, 2019 5:27 am    Post subject: Re: 800 series ford Reply to specific post Reply with quote
Thanks, this thing so fast its dangerous and I cannot control it. It shakes the whole tractor when you lift and stop. I will check out the smaller orifice first.
