No first or reverse gear
Cpenn
PostPosted: Sun Nov 17, 2019 3:59 pm    Post subject: No first or reverse gear Reply to specific post Reply with quote
Doing some bucket work with my 3444. I went to put it into reverse and heard a "clunk" noise, and then no resistance to put it in first or reverse. The other gears are fine. It's going to be a pain to remove the inspection cover because of all the hydraulics, but I hope I can get it off without having to remove the entire hydraulics housing on top of the seat.
So what do you think? Did the shifter come out of alignment off a fork or rail or something? I know that first and reverse are the same gear with the addition of an idler gear for reverse, but I am having a hard time picturing it all. I sure hope I can fix this by taking off the inspection cover on top and not have to remove the entire transmission.
Thanks,
Chad
Janicholson
PostPosted: Sun Nov 17, 2019 4:13 pm    Post subject: Re: No first or reverse gear Reply to specific post Reply with quote
If there is common parts between what you have, and this info, Part #31 might be broken. Jim
444 Trans shifter parts
