Ferguson Disk Plough
RON ALBART
PostPosted: Tue Nov 26, 2019 11:09 am    Post subject: Ferguson Disk Plough Reply to specific post Reply with quote
Looking for tail wheel furrow disk?
wellmax99
PostPosted: Thu Nov 28, 2019 8:06 am    Post subject: Re: Ferguson Disk Plough Reply to specific post Reply with quote
Ron, I have a Ferguson disc plow that I made a rear guide replacement disc.
I bought a 16" I think it was a 16" replacement plow coulter disc blade.
centered it under the old guide blade, placed 1/4" nuts between the blades then clamped them together.
took the torch stuck it thought the holed on the upper blade and blew out the holes, also cut out the center hole to fit if necessary.
the new blade fit great, never any problem with it.
I have made two guide blades like this, one for a ferguson disc plow and one for a MF Disc plow both worked fine.
RON ALBART
PostPosted: Thu Nov 28, 2019 10:43 am    Post subject: Re: Ferguson Disk Plough Reply to specific post Reply with quote
Thanks, neat idea. My bolts are past removal, did you have to drill yours out?
wellmax99
PostPosted: Thu Nov 28, 2019 4:39 pm    Post subject: Re: Ferguson Disk Plough Reply to specific post Reply with quote
I just placed the torch on the head of the bolt, let it warm up cherry red then slowly cool, when around to all bolts doing this.
then gently try to loosen the bolt, if no go, then warm them up again, this time try drowning the bolts with cold water.
this event is a long distance race, not a short sprint.
sometimes it may take three or four times of heat/cool to break them loose.
I do not remember having any problems breaking the disc blade bolts loose, but I took my sweet time.
good luck and let me know how it works out.
I also have the owners manual for these plows.
its on the 8N ford tractor site.
wellmax99
PostPosted: Thu Nov 28, 2019 4:46 pm    Post subject: Re: Ferguson Disk Plough Reply to specific post Reply with quote
note my MF 64 disc plow is the later bent tube frame model
2tractors
PostPosted: Sat Nov 30, 2019 6:22 am    Post subject: Re: Ferguson Disk Plough Reply to specific post Reply with quote
I've been on the hunt for one of the bent type now for years closest one was in Fla.
