4000 Fuel Problem, Injector pump?
Pspurg
PostPosted: Mon Dec 02, 2019 12:56 pm    Post subject: 4000 Fuel Problem, Injector pump? Reply to specific post Reply with quote
My ford 4000 diesel was idling when it began to run rough. It began belching out large quantities of black smoke and never recovered and died. When I tried to restart it sounded like it was out of time. Could this be the injector pump? What else could cause this? Can anyone point me in the right direction?
shaun wallace
PostPosted: Mon Dec 02, 2019 1:47 pm    Post subject: Re: 4000 Fuel Problem, Injector pump? Reply to specific post Reply with quote
3 cyl or 4 cyl. Helps to know witch one it is.
Pspurg
PostPosted: Mon Dec 02, 2019 1:51 pm    Post subject: Re: 4000 Fuel Problem, Injector pump? Reply to specific post Reply with quote
3 cylinder. I believe it has a cav pump. around a 1965 model
ESVADuke
PostPosted: Mon Dec 02, 2019 2:27 pm    Post subject: Re: 4000 Fuel Problem, Injector pump? Reply to specific post Reply with quote
check your tank, filter and lines for gel/gunk before you mess with he pump.
showcrop
PostPosted: Mon Dec 02, 2019 2:54 pm    Post subject: Re: 4000 Fuel Problem, Injector pump? Reply to specific post Reply with quote
Sounds like out of fuel. Do like ESVAduke said.
Destroked 450
Check the fuel system to determine if there's a good flow of fuel to the pump.
Also check the oil bath air cleaner to make sure it doesn't have water in it and froze blocking the air flow.
Pspurg
PostPosted: Tue Dec 03, 2019 1:23 pm    Post subject: Re: 4000 Fuel Problem, Injector pump? Reply to specific post Reply with quote
I will be checking through the fuel system as advised. Thank you for the help!
Robert (ID)
PostPosted: Tue Dec 03, 2019 5:50 pm    Post subject: Re: 4000 Fuel Problem, Injector pump? Reply to specific post Reply with quote
I second destroked's comment on the air cleaner... ive seen them fill with snow while cleaning the yard...
Fiveflat
PostPosted: Tue Dec 03, 2019 6:00 pm    Post subject: Re: 4000 Fuel Problem, Injector pump? Reply to specific post Reply with quote
Destroked 450 wrote:
(quoted from post at 15:54:27 12/02/19)
This.
Mine will run out of fuel even though the tank has quite a bit of fuel still in it.
I have also remove the line to the filters and blow air up into the tank (because I've been procrastinating taking the entire tank off to clean it).
showcrop
PostPosted: Tue Dec 03, 2019 7:56 pm    Post subject: Re: 4000 Fuel Problem, Injector pump? Reply to specific post Reply with quote
Fiveflat wrote:
(quoted from post at 19:00:36 12/03/19)
This.
five flat, I have removed plenty of crud from tanks by simply siphoning.
