brush cutter
NWMO 901 SOS
PostPosted: Wed May 23, 2007 5:32 am    Post subject: brush cutter Reply to specific post Reply with quote
Hey All,
I just spoke with a fellow who has a 7.5' sidewinder SWGB90 set up for 3-point for sale. He indicated it had been on a 35 hp tractor and did fine. He points out the two blade set-up gets the weight closer to the tractor which makes it easier to pick up and handle. He's been in the business for 50 years including time with his father. This makes since to me but I thought I would see if anyone thought he was blowing smoke. He is also pricing a new SE6 for me. I am going to be in his neck of the woods Friday and take a look. Any input appreciated.
Chris
souNdguy
PostPosted: Wed May 23, 2007 5:53 am    Post subject: Re: brush cutter Reply to specific post Reply with quote
A 7.5' mower.. if a standard 3pt 'hog'.. seems a bit much on a 35 hp tractor.
If it were a sickle bar.. yes.. if it was a drag mower.. -perhaps-.. maybee in light pasture.
I used to have a NH 1920.. diesel.. 33hp.. it pulled a 6' mower max....
Soundguy
NWMO 901 SOS
PostPosted: Wed May 23, 2007 6:58 am    Post subject: Re: brush cutter Reply to specific post Reply with quote
Hey Soundguy,
From an engineering perspective, moving the center of gravity nearer the rear of the tractor would be helpful for 3 point lifting and spinning two smaller blades vs. one larger blade may be easier as well?
Dean
PostPosted: Wed May 23, 2007 8:12 am    Post subject: Re: brush cutter Reply to specific post Reply with quote
Chris:
Double spindle cutters do pull easier than single spindle cutters of the same size.
Since its a double spindle and not too long it should not be too much for your 901 lift providing the total weight is not too much and your hydraulic system is good.
Your 9x1 is rated nearly 48 HP on the PTO so it should be able to handle it if you do not plan to cut very heavy cover or travel too fast.
Dean
Rick Kr
PostPosted: Wed May 23, 2007 11:09 am    Post subject: Re: brush cutter Reply to specific post Reply with quote
Chris,
A double gearbox would move the weight a lot closer to the rear of the tractor, plus it will weight a lot less.
If you are cutting field grass I think you would be ok. But cutting true brush that is a lot of mower.
My 3930 sleeps with a 6 foot brush hog in grass up to 5 foot tall. But get it in some saplings and brush, 6 foot is more that enough. I start taking 4 foot passes.
I looked at the double gear box Bush Hog model 8 foot, but I am not ready to part with $2000.
Rick
souNdguy
PostPosted: Wed May 23, 2007 11:17 am    Post subject: Re: brush cutter Reply to specific post Reply with quote
Sure it is.. however.. my guess is the mower, at that size.. is just going to be too darn big for that size tractor to operate safely.. and I'm not just talking pto hp to spin blades. I have a 10' 3pt mower on my ford 5000 .. it's as big as it wants.. and that is with 420# on the front of the tractor. I feel the 5000 would spin more blade.. but the weight on the 10' mower/3pt is pretty significant. 10' is only 2.5' bigger than 7.5' and the 5000 is a 70 hp machine.. which is 2x the size of what we are discussing IE.. a 35hp machine..
I think the 7.5' mower will be 'wagging the dog' on a 35 hp machine.
That's why i said a 'lift' style mower may actually get away with it.. etc.. same with a sickle bar.. etc..
Soundguy
NWMO 901 SOS
PostPosted: Wed May 23, 2007 3:36 pm    Post subject: Re: brush cutter Reply to specific post Reply with quote
I have not been very clear. The seller stated it had been on a 35 hp tractor, I would be putting it behind my 901, roughly 48 pto hp. I will be curious to look at it, but am leaning towards the SE6. Thank you for your input.
Chris
NWMO 901 SOS
PostPosted: Wed May 23, 2007 3:41 pm    Post subject: Re: brush cutter Reply to specific post Reply with quote
Hey Rick,
what is the HP on the 3930? I'm leaning towards the SE6 or similar, but will be curious to look at the 7.5 footer.
Chris
soundguy
PostPosted: Wed May 23, 2007 5:00 pm    Post subject: Re: brush cutter Reply to specific post Reply with quote
I'm not talking about your 900... I'm talking about that 35hp machine the dealer said it ran on... I'd like to see some proof of that one... ( not from you.. from the dealer.. )
unless he's talking 'texas hp' ( bigger than regular hp ) .. I find it hard to believe..at least for the lift / weight issue ...
I've no doubt that an average 9xx can power a 7.5' mower.
Soundguy
Rick Kr
PostPosted: Wed May 30, 2007 6:47 am    Post subject: Re: brush cutter Reply to specific post Reply with quote
Sorry for the slow reply.
My 3930 is 47hp at the PTO.
