Bad bearing gathering chain on MF ???
Lee in Wis
PostPosted: Wed Dec 11, 2019 5:41 pm    Post subject: Bad bearing gathering chain on MF ??? Reply to specific post Reply with quote
After loosening the set screw on the drive
sprocket is hex shaft ready to slide?
Wire brushed, oiled. I take it years of
wear at bearings and beveled gears are
keeping it tight. Any pointers?Thanks.
Young Mechanic
PostPosted: Thu Dec 12, 2019 6:55 pm    Post subject: Re: Bad bearing gathering chain on MF ??? Reply to specific post Reply with quote
Sometimes those hex shafts will slide by hand and others can't be moved with a big hammer. Soak it down good at each set of gears an good luck. Just worked on one last week, the bearing went out and broke the shaft, had to cut a new piece of shaft and use a coupler to reconnect it.
Mark (EC,IN)
PostPosted: Thu Dec 12, 2019 7:29 pm    Post subject: Re: Bad bearing gathering chain on MF ??? Reply to specific post Reply with quote
Cut it and get a coupler......you will be a much happier man.
Lee in Wis
PostPosted: Fri Dec 13, 2019 4:51 am    Post subject: Re: Bad bearing gathering chain on MF ??? Reply to specific post Reply with quote
Is there a set screw to loosen #12 13?
what stops the shaft from sliding when rolling, or is it just the constant force that prevents it? guys say cut, but wouldn't you need several cuts?
Lee in Wis
PostPosted: Fri Dec 13, 2019 7:35 am    Post subject: Re: Bad bearing gathering chain on MF ??? Reply to specific post Reply with quote
I just looked and see that's screw is for the top sprocket
Post new topic    Yesterday's Tractors Forum Index -> Combines and Harvesters All times are GMT - 8 Hours
