John deere 4400 mud hop
Danney970
PostPosted: Tue Jan 07, 2020 7:22 am    Post subject: John deere 4400 mud hop Reply to specific post Reply with quote
I am having problems with the mud hog axle the rear wheels are spinning too fast when in 2nd gear. After talking to mud hog they think it is a problem with one of the switches on the transmission. They could only provide me with a install manual witch was little help.I am looking for an operator and parts manual. Any help would be greatly appreciated.
Dennis
Danney970
PostPosted: Wed Jan 08, 2020 4:39 am    Post subject: Re: John deere 4400 mud hop Reply to specific post Reply with quote
Sorry got ahead of myself it is a John deere 4400 gear drive with dealer installed mud hog system
Case Nutty 1660
PostPosted: Wed Jan 08, 2020 6:47 am    Post subject: Re: John deere 4400 mud hop Reply to specific post Reply with quote
not sure these are ones you need but its a start
bush hog axle ops link
Case Nutty 1660
PostPosted: Wed Jan 08, 2020 6:48 am    Post subject: Re: John deere 4400 mud hop Reply to specific post Reply with quote
ops may not even be what i thought it was do you have a model # off yours that will help the search
Danney970
PostPosted: Thu Jan 09, 2020 5:41 pm    Post subject: Re: John deere 4400 mud hop Reply to specific post Reply with quote
Is there a tag on a mud hog axle if so were at
jfreed
PostPosted: Thu Jan 09, 2020 5:45 pm    Post subject: Re: John deere 4400 mud hop Reply to specific post Reply with quote
Just out of curiosity,why is RWA needed on such a small machine?
paul
PostPosted: Fri Jan 10, 2020 4:23 am    Post subject: Re: John deere 4400 mud hop Reply to specific post Reply with quote
Looking around those were a little special, to put hyd rear drive on a gear drive combine.....
Interesting. Sorry I?m not much help tho!
Paul
Case Nutty 1660
PostPosted: Fri Jan 10, 2020 4:30 am    Post subject: Re: John deere 4400 mud hop Reply to specific post Reply with quote
most assist axles I have seen have a tag riveted to the center housing,,
1206SWMO
PostPosted: Fri Jan 10, 2020 10:29 am    Post subject: Re: John deere 4400 mud hop Reply to specific post Reply with quote
Because they will get just as stuck as the big ones..I had a neighbor
with a 4400 JD and terra rice tires up front..In the muddy wheat
harvest of 1981 he was getting stuck all the time.....So he bought a
Mud Hog and it went lots better..He also added a M&W turbo....
However,that fall we had terrible mud again...He came over to help me...
His brother brought over a 7700 JD with RWA..They both got stuck several
times but never both at once..They kept pulling each other out..
There were lots of F2-F3 Gleaners,715 IH's etc in my area that had
Mud Hogs...They were a necessity..Below is a picture of a neighbor
mudding out beans for me..This was a brand new L2 Gleaner in
Nov 1979..
Danney970
PostPosted: Sat Jan 11, 2020 8:42 am    Post subject: Re: John deere 4400 mud hop Reply to specific post Reply with quote
After reading the install manual and looking ate the axle there is no tags they used the original axle and just replaced the ends with the drive motor ends. My biggest question is how do they regulate the axle speed the valve appears to be only on or off,forward or reverse. There are switches on transmission for each year but they appear to be just on off and to send power to valve
VicS
PostPosted: Sun Feb 02, 2020 1:07 pm    Post subject: Re: John deere 4400 mud hop Reply to specific post Reply with quote
My neighbor had one on a ihc 503. You just adjusted relief valve to where if you held the brakes it would push but not spin. Yours sounds like just needs backed off a bit. You should be able ti spot the relief valve. They were just helpers not supposed to push combine on there own.
Post new topic    Yesterday's Tractors Forum Index -> Combines and Harvesters All times are GMT - 8 Hours
