Pressure Treated landscape timbers
Steve-Maine
PostPosted: Sun Jan 12, 2020 4:01 pm    Post subject: Pressure Treated landscape timbers Reply to specific post Reply with quote
How long before landscape timbers will start rotting.
pburchett
PostPosted: Sun Jan 12, 2020 4:09 pm    Post subject: Re: Pressure Treated landscape timbers Reply to specific post Reply with quote
The last ones I bought at Walmart were not pressure treated, they were dipped. Went to Lowes and they had the same dipped timbers. I would not have known but I happened to look at the tag that was stapled to the end. I would give the dipped one just a year.
old
PostPosted: Sun Jan 12, 2020 4:16 pm    Post subject: Re: Pressure Treated landscape timbers Reply to specific post Reply with quote
You will be lucky if you get 10 years out of them if even that long
Heyseed
PostPosted: Sun Jan 12, 2020 4:20 pm    Post subject: Re: Pressure Treated landscape timbers Reply to specific post Reply with quote
If they are ground contact PT you can get 20 years, it does help if the grade doesn't let water puddle on them.
JDBRIDER
PostPosted: Sun Jan 12, 2020 6:49 pm    Post subject: Re: Pressure Treated landscape timbers Reply to specific post Reply with quote
When I need pressure treated I never buy anything thicker than 1 1/2 inch then double or triple them up. Seems the thicker stuff rots from the middle like the treatment doesn't reach center.
john in la
PostPosted: Sun Jan 12, 2020 6:53 pm    Post subject: Re: Pressure Treated landscape timbers Reply to specific post Reply with quote
I have not ever seen real pressure treated landscape timbers.
Yes they may dip them or pressure treat them to a chemical retention level of .01 lb per cu ft with MCA but that is not real pressure treating.
Any cut or scrape will revel untreated wood.
In comparison box store 2x4's are pressure treated to a chemical retention level of .15 lb per cu ft with MCA and at that level it barely meets ground contact levels.
Billy NY
PostPosted: Mon Jan 13, 2020 2:40 am    Post subject: Re: Pressure Treated landscape timbers Reply to specific post Reply with quote
I don't have any confidence in ACQ pressure treated lumber for ground contact. CCA (copper chromated arsenate) is a much better preservative, just not so easy to get, but is allowed for Ag and Industrial applications. Also depends on your ground conditions.
I used CCA lumber for sill plates onto compacted gravel for a set of front porch stairs I built for a neighbor in '96, they are still there today, stairs and sill plates.
Tony in SD
PostPosted: Mon Jan 13, 2020 3:06 am    Post subject: Re: Pressure Treated landscape timbers Reply to specific post Reply with quote
The have already "STARTED? to rot. When will the exceed their useful life depends on how many wet/dry cycles they are exposed to.
Mule Meat
PostPosted: Mon Jan 13, 2020 4:00 am    Post subject: Re: Pressure Treated landscape timbers Reply to specific post Reply with quote
CVPost-Steve-Maine wrote:
(quoted from post at 17:01:52 01/12/20) How long before landscape timbers will start rotting.
They start rotting the minute you expose them to the weather. To many variations come into play to give an accurate time frame for in which the rot to become noticeable.
Not many people here use treated post any longer for pole barn type construction. Laminated pressure treated 2 bys have taken over.
I have always thought that there could be a market for plastic landscape timbers, boarders etc by recycling all of the plastic bottles, bags and such products. I know some places have been testing rail road ties made from recycled plastic.
MarkB_MI
PostPosted: Mon Jan 13, 2020 4:23 am    Post subject: Re: Pressure Treated landscape timbers Reply to specific post Reply with quote
It depends a lot on climate, but in my experience, the cheap landscape timbers are only good for a couple of years. I think they're actually a byproduct of plywood manufacturing; they're the cores of logs after the useful veneer has been cut off. Having used landscape timbers once, I'll never use them again.
If you want something that's in contact with soil to last, it needs to be constructed of pressure-treated wood that's rated for GROUND CONTACT. Check the label on the end of the board; most treated lumber you'll find at a big-box store will not be rated for ground contact. Ground contact-rated lumber should last for decades in even the most severe conditions.
showcrop
PostPosted: Mon Jan 13, 2020 4:28 am    Post subject: Re: Pressure Treated landscape timbers Reply to specific post Reply with quote
There are some options out there. Thirty years ago I installed some actual oak railroad ties as a retaining wall. It is still retaining the dirt.
jaoneill
PostPosted: Tue Jan 14, 2020 5:47 pm    Post subject: Re: Pressure Treated landscape timbers Reply to specific post Reply with quote
Ground contact is commonly called "foundation grade" and is labeled .60 as opposed to your everyday big box store .40 PT, which is near worthless and also usually SYP, which is garbage wood to begin with. Untreated larch or locust will last much longer.
dbNga
PostPosted: Fri Jan 17, 2020 10:40 pm    Post subject: Re: Pressure Treated landscape timbers Reply to specific post Reply with quote
I heard/read years ago that "off the shelf treated lumber for ground contact has to be 4 x" I'd still look at the label on 4x4s for preservative content.
