Can a Gleaner Be Re-galvanized?
Goto page 1, 2  Next
JIBBEN
PostPosted: Mon Jan 13, 2020 3:33 pm    Post subject: Can a Gleaner Be Re-galvanized? Reply to specific post Reply with quote
I am looking at picking up a older gleaner combine and would like to reach-out to you all and ask if it is possible to re-galvanize, galvanized metal on a gleaner combine. The sheet metal is faded over the years and I have always wanted to see what the combine looked like when it was first new.
I have been looking at Rust-Oleum Bright galvanized paint. It said on the can that you can just spray it right on top of the old stuff as long as there is no rust. There are two kinds, one is called Cold Galvanized Compound, and the other is called Bright Galvanized Compound. I am wondering what is the difference between the Cold and the Bright. what is going to give me the most original color.
HenryO
PostPosted: Tue Jan 14, 2020 6:58 am    Post subject: Re: Can a Gleaner Be Re-galvanized? Reply to specific post Reply with quote
I have little knowledge of the lasting power but there is a product called GALVANOLEOM THAT CAN BE USED OVER RUST ETC. to good effect.
isaacjibben
PostPosted: Tue Jan 14, 2020 7:04 am    Post subject: Re: Can a Gleaner Be Re-galvanized? Reply to specific post Reply with quote
Where can a guy get this GALVANOLEOM? Sounds perfect!
moeszyslak
PostPosted: Tue Jan 14, 2020 9:14 am    Post subject: Re: Can a Gleaner Be Re-galvanized? Reply to specific post Reply with quote
Your talking about Zinc paint. The bright will be more silver, and the other more flat. This will not match a galvanized panel because you will not get that pattern of galvanized metal. You will in the end get a panel with chalky grey paint.
isaacjibben
PostPosted: Tue Jan 14, 2020 9:25 am    Post subject: Re: Can a Gleaner Be Re-galvanized? Reply to specific post Reply with quote
I am willing to lose the pattern in order to get the brightness and color back. If there is no way of restoring the original Galvanization of its bright color then what do I need to do without taking the hole combine apart to get back the Brightness and color?
David.DeHart
PostPosted: Tue Jan 14, 2020 1:18 pm    Post subject: Re: Can a Gleaner Be Re-galvanized? Reply to specific post Reply with quote
I have used cold galvanizing paint. I believe it was a Rustoleum product. It will come out as a flat medium gray, looks nothing like galvanized tin. It does however work great on touching up hot dipped galvanized boat trailers and anything else you want to keep from rusting. It will not match original galvanized materials though. I would think a semi gloss metallic silver paint might be your closest match. At least it would look silver and have a slight shine from a distance. By the way Gleaners had a disparaging nickname the "Silver Re-seeder". Don't know if its true, but it is funny.
isaacjibben
PostPosted: Tue Jan 14, 2020 6:44 pm    Post subject: Re: Can a Gleaner Be Re-galvanized? Reply to specific post Reply with quote
David.DeHart wrote:
(quoted from post at 14:18:13 01/14/20) I have used cold galvanizing paint. I believe it was a Rustoleum product. It will come out as a flat medium gray, looks nothing like galvanized tin. It does however work great on touching up hot dipped galvanized boat trailers and anything else you want to keep from rusting. It will not match original galvanized materials though. I would think a semi gloss metallic silver paint might be your closest match. At least it would look silver and have a slight shine from a distance. By the way Gleaners had a disparaging nickname the "Silver Re-seeder". Don't know if its true, but it is funny.
Thanks for the help! The "Silver Seeder" is a very well known quote from the early 80s when Gleaner was switching over from conventional combines to Rotary combines. they specked out the old conventional M's till grain started coming out the back, using too large of heads for the narrow threshing design it was. It took awhile till Gleaner was able to get all the bugs out of the rotary like all the other combine manufacturers, but when they did the bad name of the conventional's stuck with the rotary unfortunately.
Bob
PostPosted: Tue Jan 14, 2020 7:28 pm    Post subject: Re: Can a Gleaner Be Re-galvanized? Reply to specific post Reply with quote
Isaac, gleamers were called "silver seeders" DECADES before the era you mention.
IowaJohn
PostPosted: Wed Jan 15, 2020 8:06 am    Post subject: Re: Can a Gleaner Be Re-galvanized? Reply to specific post Reply with quote
Around here they're known as silver
pheasant feeders.
MattLF9
PostPosted: Wed Jan 15, 2020 9:33 am    Post subject: Re: Can a Gleaner Be Re-galvanized? Reply to specific post Reply with quote
CLR cleaner brings the shine back, but if
you use too much, it will remove the zinc.
isaacjibben
PostPosted: Wed Jan 15, 2020 2:32 pm    Post subject: Re: Can a Gleaner Be Re-galvanized? Reply to specific post Reply with quote
CVPost-Bob wrote:
(quoted from post at 20:28:53 01/14/20) Isaac, gleamers were called "silver seeders" DECADES before the era you mention.
Well the First Gleaner was built in a garage, so. lol
isaacjibben
PostPosted: Wed Jan 15, 2020 2:36 pm    Post subject: Re: Can a Gleaner Be Re-galvanized? Reply to specific post Reply with quote
lol, maybe that is what the Baldwin Brothers wanted when they built the first one's in there Garage!
isaacjibben
PostPosted: Wed Jan 15, 2020 2:43 pm    Post subject: Re: Can a Gleaner Be Re-galvanized? Reply to specific post Reply with quote
Thank-you! How much is to much would you say? I don't want to mess up a 83 year old machine.
Farmer Rock
PostPosted: Wed Jan 15, 2020 3:37 pm    Post subject: Re: Can a Gleaner Be Re-galvanized? Reply to specific post Reply with quote
if you are just trying to shine it up,i imagine you could oil base then clear coat it
SVcummins
PostPosted: Sun Jan 19, 2020 11:52 am    Post subject: Re: Can a Gleaner Be Re-galvanized? Reply to specific post Reply with quote
Mexi-chrome
Post new topic    Yesterday's Tractors Forum Index -> Combines and Harvesters All times are GMT - 8 Hours
Goto page 1, 2  Next
Page 1 of 2
