Load shaft shims
37chief
PostPosted: Mon Jan 13, 2020 9:03 pm    Post subject: Load shaft shims Reply to specific post Reply with quote
What is the clearance between the load shaft bushing, and the lift arm bearing? My manual doesn't mention shims, but I see them for other tractors. I would think they should be fairly snug. Mowing in rough fields I hear the arms bouncing back and forth. any thoughts? Stan
Tx Jim
PostPosted: Tue Jan 14, 2020 3:15 am    Post subject: Re: Load shaft shims Reply to specific post Reply with quote
A machinery washer with an ID of 0.900 in should be fine. Just shim all side to side movement from L/D shaft with draft links attached
tim s
PostPosted: Tue Jan 14, 2020 5:08 am    Post subject: Re: Load shaft shims Reply to specific post Reply with quote
You can get an assortment of sizes from Deere, some times you may need to sand/grind the surface area while the A-frame is down to get rid of the worn depression... do away with all the end play that you can,, too much is why the seals fail too soon.
Tx Jim
PostPosted: Tue Jan 14, 2020 5:41 am    Post subject: Re: Load shaft shims Reply to specific post Reply with quote
CVPost-Tim S wrote:
(quoted from post at 08:08:09 01/14/20) You can get an assortment of sizes from Deere, some times you may need to sand/grind the surface area while the A-frame is down to get rid of the worn depression... .
Tim
When you state "A frame" you must be thinking about rowcrop not utility tractor because as I know you're aware JD utility such as 401B has no "A frame" for 3 pt draft arms to attach to.
Hotflashjr
PostPosted: Tue Jan 14, 2020 6:41 am    Post subject: Re: Load shaft shims Reply to specific post Reply with quote
I found ones at Tractor Supply that fit my JD 1020. I think I ended up using 3 on mine to remove the play.
tim s
PostPosted: Tue Jan 14, 2020 6:59 am    Post subject: Re: Load shaft shims Reply to specific post Reply with quote
Yes,, I thought we were talking about real tractors...
37chief
PostPosted: Tue Jan 14, 2020 8:48 am    Post subject: Re: Load shaft shims Reply to specific post Reply with quote
My tractor can beat up your tractor. Stan
tim s
PostPosted: Tue Jan 14, 2020 9:39 am    Post subject: Re: Load shaft shims Reply to specific post Reply with quote
The same thing apples to utility tractors if the shaft is not shimmed up tight it will eat the load seals up...
matthies
PostPosted: Tue Jan 14, 2020 12:58 pm    Post subject: Re: Load shaft shims Reply to specific post Reply with quote
Nice reply Tim S, I have the same feeling.
SVcummins
PostPosted: Wed Jan 15, 2020 10:42 pm    Post subject: Re: Load shaft shims Reply to specific post Reply with quote
I just used shims from places like tractor supply . You want to shim them pretty tight
